Toymods » Tech & Conversions » Carb to EFI. Fuel tank question.
gabe
Carb to EFI. Fuel tank question. Wed, 22 October 2003 01:43 Go to next message
Just a quickie.....
do you need a vent of some description on your fuel tank when the charchol cannister is removed??
TRD-75
Re: Carb to EFI. Fuel tank question. Wed, 22 October 2003 01:47 Go to previous messageGo to next message
don't think so. cause when i got one of my ta22's the return line was blocked off and the charcoal canister removed. didn't make a difference.
gabe
Re: Carb to EFI. Fuel tank question. Wed, 22 October 2003 01:51 Go to previous messageGo to next message
Just trying to think how the fuel is replaced with air so the tank doesnt pull a vacuum (spelling??)
TRD-75
Re: Carb to EFI. Fuel tank question. Wed, 22 October 2003 01:53 Go to previous messageGo to next message
good point. i haven't really had a good look at the setup on the ta22.
Re: Carb to EFI. Fuel tank question. Wed, 22 October 2003 01:56 Go to previous messageGo to next message
I've seen EFI cars with charcole canisters still retained.
In my RA28 I went from carby to EFI and retained the charcole canister.
gabe
Re: Carb to EFI. Fuel tank question. Wed, 22 October 2003 02:04 Go to previous messageGo to next message
I think EFI cars still come out with charchol canisters. But I dont want one in my engine bay cause they are ugly. I realise they serve a purpose but I dont think my sprinter will be street legal anyway.
Scorpion
Menai area of Sydney
Re: Carb to EFI. Fuel tank question. Wed, 22 October 2003 03:02 Go to previous messageGo to next message
Isn't there a small breather hole in the petrol cap ?
gabe
Re: Carb to EFI. Fuel tank question. Wed, 22 October 2003 03:58 Go to previous messageGo to next message
Some may but I have had cars that suck in air when the filler cap is removed. Maybe the hole is blocked??
BansheeBuzz
Gold Coast
Re: Carb to EFI. Fuel tank question. Wed, 22 October 2003 10:20 Go to previous messageGo to next message
you need a breather and it should go through a charcol canister.
CLG
Perth, Western Australia
Re: Carb to EFI. Fuel tank question. Wed, 22 October 2003 15:42 Go to previous messageGo to next message
You can move the charcoal cannister to the rear of the car, if you don't want it in the engine bay. I'd also put a one way valve in it to negate the boost effect on it.
I also know that some cars that come out with cannisters can get away with out one legally as they are no longer available new through the dealer, with the theory being the impossibility to find one in good condition. Many Torana owners use this excuse as they can't buy new cannisters from Holden.
Personally, I'd have a one way vent in the fuel cap.
FKN16V
NSW, East Coast
Re: Carb to EFI. Fuel tank question. Wed, 22 October 2003 22:18 Go to previous messageGo to next message
The sprinter fuel nozzle will need the be changed to a efi type.
Sprinter fuel nozzles dont vent under vacumm, hence the charcol canister. You could always drill a very small hole in the standard cap to let out pressure, but its all up to you.
Just my 2c worth.
CLG
Re: Carb to EFI. Fuel tank question. Thu, 23 October 2003 01:00 Go to previous messageGo to next message
Think you mean, fuel cap?
ra23celica
Re: Carb to EFI. Fuel tank question. Thu, 23 October 2003 03:56 Go to previous message
Answer to your original question is yes, you do. If you don't want the charcoal canister in the engine bay, remove it, shorten the pipe that runs back to the tank and fit a one-way breather valve to the end of it. Otherwise you run the risk of pressuring the tank in your EFI arrangement.
There is a guy running a 1G-GZE in his RA23 and has fitted an in-tank fuel pump and is suffering big fuel smells and tank pressure problems where the cap is almost exploding off is his hands when he stops to fuel up.
Cut into the return line at the rear and move the canister to the boot and just join up the lines in the engine bay, and you will be legal. Shame to see your car yellow stickered when otherwise it could be made street legal.
Mitch.
Previous Topic:Door handle issues.
Next Topic:4agze CAS wiring diagram
Current Time: Sat Oct 17 07:06:44 UTC 2026
Total time taken to generate the page: 0.012785911560059 seconds
