Toymods » Tech & Conversions » Tuning Carbies??
Connor
Devonport, Tasmania
Tuning Carbies?? Wed, 22 October 2003 08:52 Go to next message
hey, i have a 3tc with auto choke on the stock carbie and when you start it it goes to about 3000 revs, then backs off and dies?? do i need to give it a tune or what?? and how do i do this?
connor
[Updated on: Wed, 22 October 2003 22:46]
Connor
Devonport, Tasmania
Re: Tuning Carbies?? Wed, 22 October 2003 22:46 Go to previous messageGo to next message
Anyone pllllz
Connor
Devonport, Tasmania
Re: Tuning Carbies?? Wed, 22 October 2003 22:48 Go to previous messageGo to next message
C'mon
[Updated on: Wed, 22 October 2003 22:48]
Steve M
Re: Tuning Carbies?? Wed, 22 October 2003 23:21 Go to previous messageGo to next message
Sounds like the auto choke has a few issues, try adjusting that, otherwise, it might just be dead.
Our 18rc had auto choke trouble towards the end of its use
Steve M
Re: Tuning Carbies?? Wed, 22 October 2003 23:33 Go to previous messageGo to next message
Is your temperature sender stuffed. If the choke wasn't getting propper temperature readings, it will not work properly, and would do exactly what you've outlined.
Scorpion
Menai area of Sydney
Re: Tuning Carbies?? Wed, 22 October 2003 23:45 Go to previous messageGo to next message
oops. missed the point. sorry.
[Updated on: Thu, 23 October 2003 09:23]
hotrolla
Re: Tuning Carbies?? Thu, 23 October 2003 00:36 Go to previous messageGo to next message
I think it's supposed to idle at 3000rpm for about 30sec's and then it slowly backs off that's if you pushed the accelerate all the way down that will occur.
Jayem
Finland
Re: Tuning Carbies?? Thu, 23 October 2003 17:25 Go to previous messageGo to next message
You can adjust that 3000rpm thing by bending rod(mild Z thing) that goes from fast idle rocker to choke flap mechanism and the nose that leans on to rocker. Correct rpm(from memory) when fast idle is on is about 2000rpm's. Fast idle should go off when you slightly open the throttle. Dying part is prolly caused by too lean choke mixture. That can be adjusted by turning heat wire bell clockwise->richer mixture. Check also that choke flap is fully closed at open air temperature of 20C and fully open at normal running temperature. Get repair manual for more info. Renewing and checking that vacuum hoses goes from right place to right place makes wonders also.
[Updated on: Thu, 23 October 2003 17:26]
Re: Tuning Carbies?? Fri, 24 October 2003 02:35 Go to previous messageGo to next message
Do these carbs have an idle cut off solonoid? Is it working??...
On my 2TC (and on every one of my carb'd crapheaps before it!) I just ditched the choke altogether anyway - 2 mins of grumpiness doesn't really bug me anyway Evil or Very Mad
lowlux
Re: Tuning Carbies?? Wed, 29 October 2003 02:27 Go to previous messageGo to next message
i had minor problems when my carby was rebuilt, on the 18r-c motor, the auto choke burnt out the wiring because it was shot, used to work good before i got it rebuilt
like one doode said must be a problem with the auto choke
Re: Tuning Carbies?? Wed, 29 October 2003 04:37 Go to previous message
if it dies quickly after revving up, then i'd be looking for intake leaks. i had two 0.5x5mm leaks in my manifold gaskt and it would do this. tap the throttle, revs up then dies.....
get a torch and start lookin.
Previous Topic:Tricks and traps 4AGZE into TA22
Next Topic:gearbox swap
Current Time: Wed Oct 28 18:23:30 UTC 2026
Total time taken to generate the page: 0.038227081298828 seconds
