Toymods » Tech & Conversions » a/c compressor or p/s pump squeak
STR8 2.8
a/c compressor or p/s pump squeak Wed, 22 October 2003 09:34 Go to next message
ma61 5me,
a loud squeak sound,
its either the aircon compressor or powersteering pump, hard to tell coz they're to close together,
squeak occurs when lights are turned on, or aircondtioning turned on, and gets louder when you rev the engine.
im thinkin its a bearing stuffed somewhere i dont think its the belts, maybe wrong.
any ideas?
what would i be looking at for a rebuilt pump or compressor(with regass).
the noise is driving me insane.
also the aircon makes a sorta putting whirring sound, is the comp on its way out, or is it just 20y.o. wear an tear?
Chris
V8_MA61
Re: a/c compressor or p/s pump squeak Wed, 22 October 2003 10:13 Go to previous messageGo to next message
loose belt? Squeak or squeal? My 5m did this when i replaced the water pump.
Cyber-punk
Brisbane, QLD
Re: a/c compressor or p/s pump squeak Wed, 22 October 2003 10:15 Go to previous messageGo to next message
i get a squeeky squeel somtimes when i take off
it's either that wierd emissions? air pump next to the air box
or the alternator.
i figure the bearing or whatever just need a good lube up
but i aint touching it untill it stops working....stoopid 5m-*suck*e
should be a 2jz in there dag nabbit!
V8_MA61
Re: a/c compressor or p/s pump squeak Wed, 22 October 2003 10:19 Go to previous messageGo to next message
im pretty sure itd be the belt. the one that holds the water pump and alternator. Does it especially happen at night or when the weather is colder?
Cyber-punk
Brisbane, QLD
Re: a/c compressor or p/s pump squeak Wed, 22 October 2003 10:30 Go to previous messageGo to next message
if it moves more than about 15-20mm then its too loose
well thats what i've been taught as a rule of thumb
V8_MA61
Re: a/c compressor or p/s pump squeak Wed, 22 October 2003 10:31 Go to previous messageGo to next message
15-20mmm...thats being generous..especially on that thick belt. I would've thought 7-10max on a belt like the 5m alternator one.
[Updated on: Wed, 22 October 2003 10:32]
STR8 2.8
Re: a/c compressor or p/s pump squeak Wed, 22 October 2003 10:44 Go to previous messageGo to next message
well i tightened the belt before and it still makes the noise, it makes the noise anytime the electrics are on, hot or cold, night or day
V8_MA61
Re: a/c compressor or p/s pump squeak Wed, 22 October 2003 10:47 Go to previous messageGo to next message
yeah well the bearings or bushes may be shagged in your alternator. when the air pump goes, it normally makes a knocking sound.
STR8 2.8
Re: a/c compressor or p/s pump squeak Wed, 22 October 2003 10:50 Go to previous messageGo to next message
ah i see,
how difficult is it to rebuild, can i buy parts?
im guessing brushes and bearings arent particularly hard to replace, or is there some secret bastard trick i dont know
[Updated on: Wed, 22 October 2003 10:50]
V8_MA61
Re: a/c compressor or p/s pump squeak Wed, 22 October 2003 11:08 Go to previous messageGo to next message
cheaper and easier to buy one 2nd hand...otherwise about $60 for parts. Also depends on how hard it is to find them. Although Not too hard id imagine...
STR8 2.8
Re: a/c compressor or p/s pump squeak Wed, 22 October 2003 11:20 Go to previous messageGo to next message
cool, cheers matey,
ill tear it down anyway and just have a look, try and make sure its the prob.
Re: a/c compressor or p/s pump squeak Wed, 22 October 2003 12:35 Go to previous messageGo to next message
The fact that the noise is load-dependant suggests it's a problem with the belt; it's probably just worn to buggery and needs replacement. If it was a dud bearing the noise would be constant.
wilbo666
Re: a/c compressor or p/s pump squeak Wed, 22 October 2003 12:48 Go to previous message
STR8 2.8 wrote on Wed, 22 October 2003 21:20
cool, cheers matey,
If you do decide to get a bearing / bush kit let me know how much it was / is Very Happy
Previous Topic:high pressure fuel pumps ?
Next Topic:r154 breather
Current Time: Fri Oct 16 15:33:07 UTC 2026
Total time taken to generate the page: 0.0050408840179443 seconds
