Toymods » Tech & Conversions » Another 1jz thread!!
E30-323ti
Another 1jz thread!! Mon, 22 July 2002 03:39 Go to next message
Hi all,
Finished engine mounts over the weekend, pulling the engine out again to start the wiring & put the flywheel and clutch on.
Now for the questions:
I don't have the MAP sensor for the 1jz-gte, Do I have to use a genuine Toyota one (at $400 or something silly). Or can I use an aftermarket one??
Thanks in advance.
Glenn
1JZ powered '85 BMW 323i
E30-323ti
Re: Another 1jz thread!! Mon, 22 July 2002 04:05 Go to previous messageGo to next message
Just playing with my profile settings.
Just ignore this.
E30-323ti
Re: Another 1jz thread!! Mon, 22 July 2002 04:17 Go to previous messageGo to next message
If it doesn't work this time then F*#k it!!http://www.geocities.com/ggclhm1/sign.JPG
[Updated on: Mon, 22 July 2002 04:25]
deesonet
Toowoomba
Re: Another 1jz thread!! Mon, 22 July 2002 10:25 Go to previous messageGo to next message
Glenn
I believe that you can use any MAP sensor that is 5V rated. When we couldn't get our 1JZ to start we tried a Celica unit and it worked.
Pete
gold coast
Re: Another 1jz thread!! Mon, 22 July 2002 10:33 Go to previous messageGo to next message
Most toyota Map sensed turbo cars use a similar map sensor.
I'd suggest not trying to graft on a bosch or delco 2 Bar unit.
E30-323ti
Re: Another 1jz thread!! Tue, 23 July 2002 00:02 Go to previous messageGo to next message
Thanks for your input guys.
Did either of you see the pic I put in??
Today I can't see it?? I'll try again.
[Updated on: Tue, 23 July 2002 00:03]
Re: Another 1jz thread!! Tue, 23 July 2002 00:23 Go to previous messageGo to next message
You'll have to host it some place other than geocities. Cool pic though. Should be a bag of fun.
Pete
gold coast
Re: Another 1jz thread!! Tue, 23 July 2002 08:55 Go to previous messageGo to next message
If you have probs finding one, i may be of some help.
I found one in the boot of my car this arvo???
I thought i did not get it when i picked up a motor.
It is from a JZA70.
deesonet
Toowoomba
Re: Another 1jz thread!! Tue, 23 July 2002 10:24 Go to previous message
Hi Pete
Did you know that Brent has another 1JZ motor.
This one must be from a Soarer as it is different from his old one. The waterpump doesn't have a hydraulic pump on the rear and the motor had a viscous clutch fanm on it.
Previous Topic:What fuel should be run in a 18RG
Next Topic:1GGTE spigot bearing
Current Time: Sat Oct 24 21:17:17 UTC 2026
Total time taken to generate the page: 0.008253812789917 seconds
