Toymods » Tech & Conversions » 99 WRX 4pot Calipers onto AE92?
_555_
SOR, Perth
99 WRX 4pot Calipers onto AE92? Wed, 22 October 2003 15:54 Go to next message
Just wondering if the above is do-able and if so
how much would the bracket joining the calipers to the
backing plate/axle thingy would set me back?
Also is it possible to make one of these brackets
and would a DIY braket be strong enough for a RALLY
application?
Thanks.
[Updated on: Wed, 22 October 2003 15:57]
Corvid
Re: 99 WRX 4pot Calipers onto AE92? Wed, 22 October 2003 22:07 Go to previous messageGo to next message
Anything can be done.. but seriously could you be fooked..
I reccommend you get yourself a set of jap levin Superstruts..
Hooge twin pistons with 275mm discs.. which are phat!
that would be way enough brakes for a ae92..
or if you really wanna go a 4 piston set so you can say to your mates.. "Ive got 4 pistons, blow me" then get a set of series 5 Turbo Rx7 units.. they are sooooooooooooooooooooooooooooooooooooooooooooooooo ooooooo much lighter than the wrx units../
But you still need to make adaptor plates...
whereas with teh superstruts its a bolt on unit.
after you shave 5 mill off the disc dia.
Re: 99 WRX 4pot Calipers onto AE92? Wed, 22 October 2003 23:59 Go to previous messageGo to next message
The WRX ones aren't exactly what you'd call heavy though are they?
Corvid
Re: 99 WRX 4pot Calipers onto AE92? Thu, 23 October 2003 00:14 Go to previous messageGo to next message
You ever picked a set up??!?
Then pick up a set of Rx7 jobbies?
Re: 99 WRX 4pot Calipers onto AE92? Thu, 23 October 2003 00:21 Go to previous messageGo to next message
No I haven't, thats why I'm asking, what makes them so much heavier?
_555_
SOR, Perth
Re: 99 WRX 4pot Calipers onto AE92? Thu, 23 October 2003 04:12 Go to previous messageGo to next message
Corvid, thanks for advice but the reason I was thinking about the WRX 4piston is that its for RALLYING and 4 are better than
2! and they would slow me down much easier and have more bite than the 2 piston ones.
Re: 99 WRX 4pot Calipers onto AE92? Fri, 24 October 2003 02:51 Go to previous messageGo to next message
The AE101 superstrut ones work OK, but if you're after some 4 bangers, maybe look into the Nissan ones?
Corvid
Re: 99 WRX 4pot Calipers onto AE92? Fri, 24 October 2003 02:56 Go to previous messageGo to next message
Rx7 then all the way dude.. they are cheap and very light.. lotsa bite.. a mate has a set in a rx3.. jeeeeebus;....
Re: 99 WRX 4pot Calipers onto AE92? Fri, 24 October 2003 03:18 Go to previous messageGo to next message
anyone know what the difference in piston area is between these 4 piston jobbies and other brakes??
after all, clamping force is what you are after, and that is only a ratio between the caliper piston area and your MC area, as is MC travel....
surely a 2 pot caliper with the same piston area as a 4 pot will have the same pad force for a given MC force??? then the only difference would be the 'even-ness' of load across the pad, giving more even pad wear (assuming same size pads??
or am i completely wrong??
Re: 99 WRX 4pot Calipers onto AE92? Fri, 24 October 2003 07:51 Go to previous message
The Subaru ones are cast iron, hence the big weight difference Smile Just found out Razz
Previous Topic:Supra MK3 Brake Rotors To Fit GZ20 Soarer?
Next Topic:inductive speed sensor .. how they work?
Current Time: Fri Oct 16 13:06:20 UTC 2026
Total time taken to generate the page: 0.0047910213470459 seconds
