Toymods » Tech & Conversions » excessive Idle
MaNGeW
Formerly TRD_RoLLa
icon2.gif  excessive Idle Thu, 23 October 2003 00:55 Go to next message
My car idles too high.
Despite having the idle screw adjusted all the way down.
It idles between 1500-2000rpm. All the time.
I on average have to reset my ecu weekly basis.
To temporary rectify the problem, but soon climbs back up.
Ive always had this problem. But just lived with it past 12 months.
Engine is a MAP GZE with air-con removed.
Would adjusting the TPS help?
Or is it a faulty cold start injector?
Theres no wax pellet in the 4agze ? i know the 4age have them
Its pissing me off.
Coz it make driving annoying.
When driving along and upon gear changes the idle rises up between gears and makes the gear transition rough.
Crying or Very Sad
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: excessive Idle Thu, 23 October 2003 01:09 Go to previous messageGo to next message
Air leak?
You checked all your piping?
One trick is to spray degreaser at places where you might have a possible leak while the engine is running...
whiteGZE
Western Sydney
Re: excessive Idle Thu, 23 October 2003 02:49 Go to previous messageGo to next message
As Nark has said, check again for an air leak, this could also be causing your boost problems.
Something you can try is put your top mount ic back on and see how the car behaves.
IRA11Y
Club Member
Re: excessive Idle Thu, 23 October 2003 06:18 Go to previous message
as above and check aircon idle adjustment settings and cold start idle settings, could also be a faulty temp sensor
Previous Topic:wntd ke20 brake conv
Next Topic:wheel balancing
Current Time: Sun Oct 18 01:36:06 UTC 2026
Total time taken to generate the page: 0.0061659812927246 seconds
