Toymods » Tech & Conversions » 7A-FE tachometer installation
fish0
7A-FE tachometer installation Thu, 23 October 2003 10:34 Go to next message
does anyone know where the tacho signal wire goes on these engines? i have heard it goes to the negative side of the ignition coil although i have some kind of internal ignition coil that is in the distributor.
dave
Alchemist
Re: 7A-FE tachometer installation Thu, 23 October 2003 12:50 Go to previous messageGo to next message
It goes to the -ve of the coil, or the tacho ouput(if your car already has a tacho). Sometimes the coil can be in or right near the distrib cap. Have a fish around with a multimeter(being careful!) or take it to an auto elec, get him to probe the wires for you then hook it up at home.
CrAiGzEE
south of the big smoke
Re: 7A-FE tachometer installation Fri, 24 October 2003 01:26 Go to previous messageGo to next message
there is a signal behind the cluster
black wire not plugged into anything unless u have a tacho in the dash
Johnny
Sydney, OZ
Re: 7A-FE tachometer installation Fri, 24 October 2003 02:53 Go to previous message
The there's two wires (black and yellow) that come out of the dizzy two a seperate two wire plug (small one, not the big 4 wire) if standard wiring, the yellow goes to a black/yellow stripe wire and the other connects to a black wire which goes to the diagnosis plug.... connect the signal to the tacho to the BLACK. Any where else, you'll blow your tacho.. Al, 7AFE has internal coil, igniter, etc (one unit).... really bitch if something goes wrong!!
Previous Topic:AE82 OEM Camber Bolts (Need Parameters)
Next Topic:Attn: IRA11Y, Re: Brake Upgrade Article
Current Time: Fri Nov 20 06:51:17 UTC 2026
Total time taken to generate the page: 0.0046529769897461 seconds
