Toymods » Tech & Conversions » consequences of too much power?
Byatch
consequences of too much power? Fri, 24 October 2003 06:47 Go to next message
hey all,
i am sure someone has asked this question before, buti couldn't seem to find it, so i'll ask it again.
what are the consequences of too much power in an older car.
i know what has to be upgraded -
brakes, suspension, enigine mounts, drivetrain etc..
but what i really want to know about is the effects on the car itself; will it take the increased power being delivered? will the car twist too much and do all sorts of other stupid stuff?
oh, prbly should give you all some stats:
car - rt104 Corona
currrent engine - 18rc (worked)
proposed engine - 1gg(t/z)e
any thoughts on the matter?
Lambolica
Northwestern Sydney
Re: consequences of too much power? Fri, 24 October 2003 06:56 Go to previous messageGo to next message
If you spend alot of time lanching your car, the tourqe in the engine can twist the chassis and body over time and weaken or break spot welds. I'll be putting a 1G-GTE in to my car and I'll be welding up all the seams before it goes in. Some engineers like to see this done to pass as well.
I'm guessing that increasing overall performance of the car (suspension bigger wheels etc.) would also adversly effect the standard fixing points of the steering suspension as one can corner harder thus placing more stress on them. I haven't heard of anyone beefing up steering components or mounts however.
coronamark2
Re: consequences of too much power? Fri, 24 October 2003 06:57 Go to previous messageGo to next message
course it will its metal Laughing
get weldi!
< im planning on a 7mgte in that lets see if the wheels fall off Laughing
Byatch
Re: consequences of too much power? Fri, 24 October 2003 07:01 Go to previous messageGo to next message
i did, that is with the steering.
well, ok, not beefed up, just took the whole system apart and got everything checked and rechecked. thought it was a good idea, and i don't regret the cash i coughed up for it.
so the general consencus is to get out there and uber-weld it up
other thoughts?
Re: consequences of too much power? Fri, 24 October 2003 14:03 Go to previous messageGo to next message
Unless you're building a race car I wouldn't worry about welding up the chassis. Sure a 1G has a lot more power than an 18R-C, but it's hardly a torque monster. RT104's are fairly robust anyway.
Lambolica
Northwestern Sydney
Re: consequences of too much power? Fri, 24 October 2003 14:11 Go to previous messageGo to next message
Norbie,
I've spoken to an engineer on the subject.. he, in a round about way, said I'd need to weld up the seams to pass it is this correct?? I hadn't heard of this before.
and in respect to the question of TOO much power I was visualising enough power to lift the front of the car significantly. But how much power is too much power???
Re: consequences of too much power? Fri, 24 October 2003 14:52 Go to previous messageGo to next message
I have a 400hp engine in my Supra (original power output was approx 120hp on a good day), but my engineer made no mention of seam welding or anything of that sort. I have quite a few friends who have done big HP engine conversions and none of them have been required to do any chassis strengthening either. I can see it being required in extreme circumstances, but a 1G Corona isn't what I'd call extreme.
Cyber-punk
Brisbane, QLD
Re: consequences of too much power? Sat, 25 October 2003 00:51 Go to previous messageGo to next message
at the end of the day it all depends on what the engineer wants you to do to pass it
they could probably say they wont engineer it unless you put on fluffy door trims in psychedelic yellow
CLG
Perth, Western Australia
Re: consequences of too much power? Sat, 25 October 2003 07:06 Go to previous messageGo to next message
Consequences??? Ummmm, a big grin and an empty wallet!!!
Re: consequences of too much power? Sun, 26 October 2003 01:49 Go to previous messageGo to next message
Consequences... black tracks, and splintered power poles - it's amazing how roadside furniture can move over Evil or Very Mad
As for strength, an RT104 would look tough with a fat roll cage Surprised
ChuckLandwehr
Re: consequences of too much power? Sun, 26 October 2003 09:42 Go to previous messageGo to next message
Hi Byatch, I have had an RA28 engineered with a 1G-GTE, no seam welding required. Ok I live in Canberra, but the standards used in the ACT are lifted from NSW, so the engineer only required a disc brake up grade (MX63 cals.RT132 struts, RA60 disks). I have a good friend who did the same mods to his TA23 Celica, he lives in NSW. But before starting any conversion, talk to an engineer. Their advice is free, but the engineering report/ certificate is what you pay for.
good luck with the conversion, Chuck.
Mr DOHC
Re: consequences of too much power? Sun, 26 October 2003 12:15 Go to previous messageGo to next message
consequences: hard-on Very Happy
btw, go the mighty RT104
u WILL have problems with diffs and suspension, trust me Rolling Eyes
crostek
Oyster bay NSW
Re: consequences of too much power? Sun, 26 October 2003 14:37 Go to previous message
Like every one is saying talk to an engineer. and get there advise. Is sum cases they do a test on the cars chassis for twist strength. but a 1g should be fine in a RT104 they already have a box section front sub chassis.
As for the ultament Consequence, Worked 5Lt(305cu) Chev in RA40, first burn out car twisted and back window shattered. Laughing
Previous Topic:4agze into ke25 conversion
Next Topic:Bad camber on rear of ae82, how to fix?
Current Time: Sun Oct 18 14:34:45 UTC 2026
Total time taken to generate the page: 0.042008876800537 seconds
