Toymods » Tech & Conversions » 4agze into ke25 conversion
rolyroll
4agze into ke25 conversion Fri, 24 October 2003 07:36 Go to next message
what is involved in this conversion as in engine mounts, gearbox, diff etc
rolyroll
icon5.gif  Re: 4agze into ke25 conversion Fri, 24 October 2003 08:05 Go to previous messageGo to next message
please help im totally new to this sort of converision
STR8 2.8
Re: 4agze into ke25 conversion Fri, 24 October 2003 12:03 Go to previous messageGo to next message
i cant help u with much but i do know that the ke25 tran tunnel doesnt allow much in teh way of gearboxes. ud use a t50 i guess but it won't hold up to much power. u need to cut out and remake teh tunnel larger to fit anyithing else ie. w5x
STR8 2.8
tried a search?
im sure theres info around here somewhere
Re: 4agze into ke25 conversion Sat, 25 October 2003 07:09 Go to previous messageGo to next message
rolyroll wrote on Fri, 24 October 2003 17:36
custom engine mounts, T50 fits, W doesn't, Diff will need to be upgraded to maybe T series.
a few ppl have done it in the club, so get in contact with them.
you also need brakes Wink
ke382TG
Re: 4agze into ke25 conversion Sun, 26 October 2003 22:08 Go to previous message
HI,
as mentioned you will need to make some new engine mounts, if you use the T50 box and the standard KE25 gearbox crossmember it will line up with one of the gearbox mounting points under the car (there are two sets of gearbox cross member mounting points on the chassis rails, sometimes the second set is covered by underbody tar). GO a new diff diff and tailshaft. My car had a t-series diff in it whilst supercharged and it was ok, but as soon as it was turboed it snapped or twisted 4 axles. I would recommend that if you are fitting a diff without shortening it, then a t-series may be ok. If you go to the trouble of having something shortened then go for something stronger so you you only have the expense once.
You can fit a W series gearbox in with some tunnel mods. Mine has a W58 and none of the tunnel was cut up to fit it, just a bit of panel beating in certain spots was enough.
Shane.
Previous Topic:help ae86 windscreen wipers wont work
Next Topic:consequences of too much power?
Current Time: Tue Oct 20 01:07:33 UTC 2026
Total time taken to generate the page: 0.0066521167755127 seconds
