Toymods » Tech & Conversions » My 4AC engine problem -need help
Satoshi
My 4AC engine problem -need help Fri, 24 October 2003 08:46 Go to next message
i have this problem with my 4ac engine...every time i start the engine..smelly and smokes will come out...i dont know whether this is white smoke or normal smoke...
the engine idles like its so dead...like missing out of one spark plug....but when i drive it for a lil longer..it becomes normal but still jerks at the green lights (stationary -> 1st gear acceleration)...as long as it is moving for a moment..the engine seems fine...
whenever my car stops (like 5 minutes) or i start my engine...when i accelerate...the car seems to be shaking and i feel like there's some auto parts under the car is not tight..
any advice or diagnosis i can do, and how can i fix this problem...
IRA11Y
Club Member
Re: My 4AC engine problem -need help Fri, 24 October 2003 22:37 Go to previous messageGo to next message
do a compression test,if the compression is fine make sure the timing is set correctly, if all else fails change the leads, dizzy cap,points and plugs and see if that helps
Satoshi
Re: My 4AC engine problem -need help Sat, 25 October 2003 03:15 Go to previous messageGo to next message
if my headgasket is blown...what's the sign coming out of the car besides creamy under the the valve top?
IRA11Y
Club Member
Re: My 4AC engine problem -need help Sat, 25 October 2003 03:26 Go to previous messageGo to next message
oil in the radiator
Re: My 4AC engine problem -need help Sat, 25 October 2003 04:49 Go to previous messageGo to next message
bubbles in radiator or excessive pressure in radiator when running just afte a cold start.
Satoshi
Re: My 4AC engine problem -need help Sat, 25 October 2003 12:24 Go to previous messageGo to next message
today i opened up my oil cap and look at it..its has this creamy stuff covering the top...is that a sign too?
Callifo
Gawler, SA
Re: My 4AC engine problem -need help Sat, 25 October 2003 12:29 Go to previous messageGo to next message
What colour does the oil come out on the dipstip when you pull it out.
Water in the oil and a chocolate milkshake in the radiator is a bad thing.
truenosedan
Re: My 4AC engine problem -need help Sun, 26 October 2003 04:10 Go to previous message
i know this has been said b4 and im gulity of spending money on my 4ac but in all seriousness, if you cant change the headgasket yourself, or cant identify the source of the problem, just get an age in there
Previous Topic:MZ20 Soarer Brake Pads
Next Topic:turbo on an 18rc engine.
Current Time: Sat Oct 24 04:00:56 UTC 2026
Total time taken to generate the page: 0.0056998729705811 seconds
