Toymods » Tech & Conversions » Fuel Return line?
sleeka73
Fuel Return line? Fri, 24 October 2003 09:24 Go to next message
Does anybody know why the fuel return line on my ta22 would be capped off at the tank and removed? efi maybe?
[Updated on: Fri, 24 October 2003 09:25]
Re: Fuel Return line? Fri, 24 October 2003 09:29 Go to previous messageGo to next message
Cause thats the first thing you do when you fit a different carby to the stock 2T!
sleeka73
Re: Fuel Return line? Fri, 24 October 2003 09:56 Go to previous messageGo to next message
i dont see why they had to rip the actual line out though
sleeka73
Re: Fuel Return line? Fri, 24 October 2003 09:58 Go to previous messageGo to next message
anyway, should i just bend up a new line or source one from a wreck? whats easier?
Re: Fuel Return line? Fri, 24 October 2003 10:05 Go to previous messageGo to next message
You can probably bend one up yourself or get just get one from a wreck! What ever is easier.
sleeka73
Re: Fuel Return line? Fri, 24 October 2003 10:14 Go to previous messageGo to next message
thanks 4 the info cool1
Re: Fuel Return line? Fri, 24 October 2003 10:20 Go to previous messageGo to next message
No worries mate Cool
mynameisrodney
Kellyville, Sydney
Re: Fuel Return line? Sat, 25 September 2004 08:36 Go to previous messageGo to next message
my return line is disconnected too (in my 2tg ta22). can i leave it as is or should i hook it back up.
chris
Re: Fuel Return line? Sat, 25 September 2004 08:52 Go to previous messageGo to next message
Leave it.
Re: Fuel Return line? Sat, 25 September 2004 09:11 Go to previous messageGo to next message
but where is the fuel pump going to bleed off the excess fuel?
Re: Fuel Return line? Sat, 25 September 2004 09:41 Go to previous messageGo to next message
A 2tg doesent use a high pressure pump so no bleed off is required.
greenta22
Dandenong Ranges, VIC
Re: Fuel Return line? Sat, 25 September 2004 10:38 Go to previous messageGo to next message
i believe that some carbies had return lines so that the fuel could be circulated and wouldnt heat up too much and evaporate in the float bowls. im not sure which carbs do and which dont. my downdraught solex uses a return.
Anyone know if PPH solexes (2TG) need the return line?
Re: Fuel Return line? Sat, 25 September 2004 11:06 Go to previous messageGo to next message
greenta22 wrote on Sat, 25 September 2004 20:38
i believe that some carbies had return lines so that the fuel could be circulated and wouldnt heat up too much and evaporate in the float bowls.<snip rest>[/b]
my understanding is that return line may:
-come from the fuel pump where it (the pump) maintains consistent fuel pressure in the line from pump to carbi(s)
-come from carbi(s) where the needle-valve controlling the petrol level in the float bowls is able to hold back excessive pressure or has a return valve attached to the petrol-in-line that bleeds off excess pressure(fuel) back to the tank
fwiw: some of the cheap solid-state electric (low pressure, high volume) pumps will regulate pressure alleviating the need for a return line.
mynameisrodney
Kellyville, Sydney
Re: Fuel Return line? Sun, 26 September 2004 05:16 Go to previous message
cheers guys, i'll do a neater job of blocking the line but wont rip it out.
chris
Previous Topic:Microtech hand controller
Next Topic:TA22 ????
Current Time: Wed Oct 14 09:58:53 UTC 2026
Total time taken to generate the page: 0.040699005126953 seconds
