Toymods » Tech & Conversions » turbo on an 18rc engine.
people100
Rocklea qld
turbo on an 18rc engine. Fri, 24 October 2003 10:53 Go to next message
As the subject says. How hard is it. can it be done. how will it go afterwards.
sleeka73
Re: turbo on an 18rc engine. Fri, 24 October 2003 11:01 Go to previous messageGo to next message
wouldnt tuboing a 18rgeu be easier, cheaper and gain better results?
clancey
Re: turbo on an 18rc engine. Fri, 24 October 2003 11:11 Go to previous messageGo to next message
The single cam heads are pretty restrictive as far as flow goes, you'd be a hell of a lot better off with a twin cam version of the motor.
If you could get a turbo manifold from someone cheap, it might be a bit of fun to play around with. Because lets face it, would you cry if you blew an 18r-c up Smile However I wouldn't be bothered getting a manifold custom made or pay big money for one.
clancey
Re: turbo on an 18rc engine. Fri, 24 October 2003 11:14 Go to previous messageGo to next message
Plus I'd assume you would be running a carby, which is always a pain to run forced induction through (comparitively speaking of course)Smile.
Re: turbo on an 18rc engine. Sat, 25 October 2003 04:45 Go to previous messageGo to next message
I've done this... follow link below to car...
Expect to spend a quite few peso's as there's no manifolds you can use - so you gotta make a custom job for intake + exhaust
Plus the head needs machining to lower compression
Expect lots of heat issues to deal with (suggest HPC for everything inc piston tops).
I would advise choosing an engine with a cross-flow head and EFI manifold - less hassles in the long run. 4AGZE (well, maybe?), 3SGTE (is that the right code or is it 3TGTE?), 1G-GTx, 18RGx etc
however, if you do it, you'll be in an elite club Cool
(updated to get my codes right)
charles.
[Updated on: Sat, 25 October 2003 09:27]
Classique71
Colac, Victoria
Re: turbo on an 18rc engine. Sat, 25 October 2003 07:07 Go to previous messageGo to next message
To be honest - if you want turbo power - you really are better off loking at a 1ggte swap - or a 3tgte swap .
If you can find a 18rgeu - even better !! ther are a lot simpler conversion to undertake - though you may have to look at a stronger clutch , and some engine stegthening if you want to run higher boost levels
18rc is a good economotor - they sadly are not a " performance " one , Sorta like the 5sfe , and 4ac toyota motors
Allan
Re: turbo on an 18rc engine. Sun, 26 October 2003 03:17 Go to previous message
whatever you do, do not run a petrol carby! go EFI or atleast LPG is a little easyer to set up for turbo
as for lowering compression not on an 18R-C its a perfect 8.5:1 allredy
Manifolds what i would do is go for a J pipe off the stockie or get a flange welded to where the stocky "hot spot" for the carby is then use original outlet for the wastegate... not ideal but would work, would require a custom inlet but the stock 18R inlet manifold sucks anyway
Have fun!
Previous Topic:My 4AC engine problem -need help
Next Topic:Steering Rubber Coupling Replacement Article
Current Time: Sat Oct 24 19:03:22 UTC 2026
Total time taken to generate the page: 0.0044980049133301 seconds
