Toymods » Tech & Conversions » second hand turbos - what to look for
dorikin
NE Melbourne
second hand turbos - what to look for Sat, 25 October 2003 02:47 Go to next message
i did a quick search on the forums and couldn't find much info. could anyone suggest things to look for when buying a second ahnd turbo?
Sprinta
Re: second hand turbos - what to look for Sat, 25 October 2003 03:19 Go to previous messageGo to next message
Shaft play forwards and side to side
most 2nd hand turbos will have a tiny bit but if you wriggle it with your finger and can feel it its probably too much
the more shaft play = the more chance the blades will hit the housing = bad
In saying that, 'apparently' ball bearing turbos have a tiny bit of play from factory but i wouldnt go shopping for a turbo based on that..
You want no more than 0.5mm play i guess and thats probably too much
Umm what else... basically the condition of the blades, any chips etc = bad
Hard to check oil seal if the turbos off the car
TE72_Turbo
Re: second hand turbos - what to look for Sat, 25 October 2003 04:13 Go to previous messageGo to next message
roughly what sort of turbo are you after? Toyota? Nissan? ball bearing, or bush bearing? ceramic or steel?
Phil
dorikin
NE Melbourne
Re: second hand turbos - what to look for Sat, 25 October 2003 06:06 Go to previous messageGo to next message
looking for something to use with 4AGTE conversion. either nissan or toyota, ball bearing would be nice, but not essential.
Sprinta
Re: second hand turbos - what to look for Sat, 25 October 2003 06:51 Go to previous messageGo to next message
T28 Smile
CLG
Perth, Western Australia
Re: second hand turbos - what to look for Sat, 25 October 2003 07:03 Go to previous messageGo to next message
Yep T28 ball bearing, go and buy one new for around $1400-1500, even good second hand ones can hide problems. I bought a brass bearing T28 that felt perfect, however upon inspection it was found to have been oil starved at one point. A set of oversize bearings and a rebuild later ($920), I had a good turbo (fortunately I paid peanuts for it originally so it didn't worry me)!
TE72_Turbo
Re: second hand turbos - what to look for Sun, 26 October 2003 09:38 Go to previous messageGo to next message
As clintgodde said, you cant go wrong with a brand new GT25 (320hp) for around $1500. They are a fantastic match for the 4AG, with excellent response & no loss at the top of the revs.
I dont really trust buying second hand turbos unless I've seen the car running that it came from, unless its cheap enough to not care about the condition and take a chance. Its easy to see problems with the physical condition of wheels, and feel for shaft play, but its just as expensive to change oil seals as it is for a full rebuild, and its hard to tell if it has this problem if the previous owner hits it with some degreaser before you see it Sad
Any later model T25/28 turbos (ball bearing or not) are hard to come by because of their popularity at the moment. Expect to pay around $600 for a bush bearing model, and $800+ for ball bearing, unless you can find a cheap private sale.
My bush bearing S14 200SX T28 may be for sale soon.....
Phil
onejayzed
Re: second hand turbos - what to look for Tue, 28 October 2003 03:39 Go to previous messageGo to next message
a pair of ex-starlet CT9s would be "interesting"... Razz
dorikin
NE Melbourne
Re: second hand turbos - what to look for Thu, 30 October 2003 11:54 Go to previous messageGo to next message
so you suggest that a brand new GT25/28 is the go??? where does one go to buy new turbos?
hey Phil, did you fabricate you own exhaust manifold? do you ahve any pictures of it? i'm about to start doing one myself!
TE72_Turbo
Re: second hand turbos - what to look for Thu, 30 October 2003 13:32 Go to previous messageGo to next message
Best value place to buy is www.horsepowerinabox.com
This website is run by RPM Performance centre, a very reputable workshop.
Yes I fabricated my manifold. There's a pic of it here:
http://www.geocities.com/te72_turbo/4AGTE_turboman ifold.html
but it now has a T25 flange, not the huge cumbersome CT26 one that you see in the pictures.
Phil
jackel
Re: second hand turbos - what to look for Thu, 30 October 2003 17:21 Go to previous messageGo to next message
why do turbos cost so much in value?? Confused
i could buy a good car for the price of some of them Surprised
TE72_Turbo
Re: second hand turbos - what to look for Fri, 31 October 2003 11:13 Go to previous message
Any mechanical item that can spin at around 80,000rpm for 100,000km without any servicing should be worth something Smile
Previous Topic:Oil leak from diff
Next Topic:Forced induction on a 20V 4AGE
Current Time: Fri Oct 30 12:20:23 UTC 2026
Total time taken to generate the page: 0.0046310424804688 seconds
