Classifieds » Parts Wanted » WTD 1JZ or 2JZ Front Sump
deesonet
Toowoomba
WTD 1JZ or 2JZ Front Sump Sat, 25 October 2003 09:46 Go to next message
Need front sump for 1JZ or 2JZ engine for conversion underway. Need the aluminium upper sump body, baffle plate, oil pickup, and lower steel sump.
Can swap for rear unit if required.
deesonet
Toowoomba
Re: WTD 1JZ or 2JZ Front Sump Sat, 01 November 2003 03:33 Go to previous messageGo to next message
Even will buy complete 2JZ-GE if necessary to get the front sump.
Anyone able to help???
ChuckLandwehr
Re: WTD 1JZ or 2JZ Front Sump Sun, 02 November 2003 11:35 Go to previous messageGo to next message
Hi there Graham, I have been contracted to install a rear pan sump 1JZ-GTE into an RA23. I am thinking that a front pan sump, might give me the opportunity to utilize a TA23 x member, and possibibly change the steering to r + p. will investigate!
Another alternative, is my good Toyota parts man whom I have known for 30 years, he has a reliable source of all things Toyota through a wholesale used parts supplier in QLD. The wholesaler does not deal direct wiyh the public Dammit! The last sump conversion cost me about $400.00.
regards Chuck.
JAZE
cronulla
Re: WTD 1JZ or 2JZ Front Sump Mon, 03 November 2003 12:12 Go to previous messageGo to next message
i can get you one no worries, my number is 0422 2459 494.
cheers.
deesonet
Toowoomba
Re: WTD 1JZ or 2JZ Front Sump Tue, 04 November 2003 11:18 Go to previous messageGo to next message
Chuck
Who is your supplier up here??
Jaze
Check your phone number - it has one too many numbers in it unless the numbers down south have an extra digit in them. I'll give you a call from work tomorrow.
JAZE
cronulla
Re: WTD 1JZ or 2JZ Front Sump Tue, 04 November 2003 12:18 Go to previous message
lol, soz - 0422 259 494
we are a bit weird here in the deep south
Previous Topic:TA22 Bonnet vents and interior knobs
Next Topic:ke70 back door trims (2)
Current Time: Mon Nov 2 06:07:16 UTC 2026
Total time taken to generate the page: 0.04552698135376 seconds
