Toymods » Tech & Conversions » ID'ing a 1JZ-GTE
thefonz
Numinbah Valley QLD
ID'ing a 1JZ-GTE Sat, 25 October 2003 11:06 Go to next message
I need to ID this 1JZ so i can find a wiring diagram for it.
http://www.fairgo.biz/pics/2.jpg
Notice it has TRC, also it had one of those hydraulic fluid fans (wich i replaced), Also i can post some pics of the ECU if it helps..
Is there any numbers on the motor or ecu that will tell me what model it is??
Cheers...
Re: ID'ing a 1JZ-GTE Sat, 25 October 2003 12:03 Go to previous messageGo to next message
is that another 1jz in an ma61? Razz
I'm not sure which 1jzs had the fluid fan, but try a search, as most (?) came with clutch fans
Danish
Re: ID'ing a 1JZ-GTE Sun, 26 October 2003 10:59 Go to previous messageGo to next message
It's the same as mine. The outlet from the turbo's comes out at a 90 degree angle, it has TRC and the crank case vent hose goes past the rubber flex joint on the intake as well. So it's, i think a second generation, Toyota Chaser engine.
hobpedlar
Re: ID'ing a 1JZ-GTE Sun, 26 October 2003 13:08 Go to previous messageGo to next message
Are you after full chassis wiring or just the engine?
hobpedlar
Re: ID'ing a 1JZ-GTE Sun, 26 October 2003 13:23 Go to previous messageGo to next message
ps
try here
http://www.supras.nl
westie
sideshow
Re: ID'ing a 1JZ-GTE Sun, 26 October 2003 23:43 Go to previous messageGo to next message
if u get stuck doin the wiring ill be in noosa/coloundra area
this week
i have wired up many 1js and i have all my tools with me
if u want me to do the job
my mob is 0415 904 947
Jim
Celia-Sue
Re: ID'ing a 1JZ-GTE Tue, 28 October 2003 02:56 Go to previous message
That looks a lot like my JZX90 Chaser/Mark II/Cresta motor. If so, you'll have trouble finding wiring diagrams (JZX81, JZX100, JZA70 and Soarer diagrams are all available on the web).
What are you planning to do with it?
cheers,
Justin
JZA61
Previous Topic:1JZ conversion problem - Sump fouling front universal joint
Next Topic:18rgu efi questions
Current Time: Fri Oct 23 18:28:10 UTC 2026
Total time taken to generate the page: 0.0057229995727539 seconds
