Toymods » Tech & Conversions » 1JZ conversion problem - Sump fouling front universal joint
Skip
1JZ conversion problem - Sump fouling front universal joint Sat, 25 October 2003 11:06 Go to next message
Right were the sump plug is my sump is fouling the universal joint on the front diff of my Bundera. Just was wondering if there are any narrower or different geometry sumps, ive heard that there are 2. I have a photo of the sump fouling the UJ, but for me to display it here, i need a host, volenteers? The photo below shows the type of sump I have, what car would have my engine come out of anyway?
http://mkiiisupra.homeip.net/images/1jz/andrews_1jz/my1jz_3.jpg
Skip
Re: 1JZ conversion problem - Sump fouling front universal joint Sat, 25 October 2003 11:07 Go to previous messageGo to next message
Geez that photo is big Rolling Eyes
wilbo666
Re: 1JZ conversion problem - Sump fouling front universal joint Sat, 25 October 2003 11:15 Go to previous messageGo to next message
lol want me to resize it for ya?
Skip
Re: 1JZ conversion problem - Sump fouling front universal joint Sat, 25 October 2003 11:23 Go to previous messageGo to next message
Sorry it's not my photo, it's a link from somebodys website.
Skip
Re: 1JZ conversion problem - Sump fouling front universal joint Sat, 25 October 2003 11:27 Go to previous messageGo to next message
Oh yeah, if it helps to ID what car my 1JZ came from, it had a clutch fan on the front. I notice the JZA70 supras have a thermofan.
Re: 1JZ conversion problem - Sump fouling front universal joint Sat, 25 October 2003 12:00 Go to previous messageGo to next message
cant actually see much of the sump from that pic, but it looks like a mid/rear sump type.
A front sump (such as the one off a Chaser 1jz) will almost certainly fix your fouling problems.
Be prepared for a hunt tho - they're a bit rare, and typically a bit expensive.
see if you can find a place that will swap you a chaser sump for your sump + a little bit of cash
Skip
Re: 1JZ conversion problem - Sump fouling front universal joint Sun, 26 October 2003 00:01 Go to previous messageGo to next message
I assume you will need the chaser pickup aswell?
Skip
Re: 1JZ conversion problem - Sump fouling front universal joint Sun, 26 October 2003 00:23 Go to previous messageGo to next message
Another question, is there different types of 1JZ engine mounts?
Re: 1JZ conversion problem - Sump fouling front universal joint Sun, 26 October 2003 01:20 Go to previous messageGo to next message
yeah, you'll probably want chaser pickup (not sure if that's essential) but definitly need a chaser dipstick.
cant comment on the mounts - mine are custom
Skip
Re: 1JZ conversion problem - Sump fouling front universal joint Sun, 26 October 2003 03:39 Go to previous messageGo to next message
What is your 1JZ in draven?
Went to TRD-KINGSWOODs site, and found an excellent drawing of the different sumps. Because they are two piece, i think it will be much easier for my to just fabricate a new lower section, ive probably got no chance of finding a chaser sump in WA. It's not fouling by a massive amount anyway.
Re: 1JZ conversion problem - Sump fouling front universal joint Sun, 26 October 2003 12:17 Go to previous messageGo to next message
mk2 supra (ma61)
BlackSupra
Re: 1JZ conversion problem - Sump fouling front universal joint Mon, 27 October 2003 01:53 Go to previous messageGo to next message
You will need windage tray, pickup and take your pick of front, mid/rear or rear sumps.
I have a mid/rear supra dipstick in my front sump...have no idea of its effectiveness
theyre different lengths - someone posted a pic for me a few months ago
BlackSupra
Re: 1JZ conversion problem - Sump fouling front universal joint Mon, 27 October 2003 01:59 Go to previous messageGo to next message
WHy is this, they both seemed to be similar of depth to me
meh not that it matters much, they dont burn oil anyway Smile
Pete
gold coast
Re: 1JZ conversion problem - Sump fouling front universal joint Mon, 27 October 2003 09:33 Go to previous messageGo to next message
Yep dipsticks are different too. I compared them a while back.
1J bundera, oh yeah. What tranny are you running??
Skip
Re: 1JZ conversion problem - Sump fouling front universal joint Mon, 27 October 2003 23:27 Go to previous messageGo to next message
Im running the standard R151f. These and the R150 have a 30mm shorter input shaft than the R154, luckily for me dellow had a bellhousing to suit.
wastegate
Gold Coast
Re: 1JZ conversion problem - Sump fouling front universal joint Tue, 28 October 2003 04:31 Go to previous messageGo to next message
That engine you have there looks to be out of a Soarer. They are mid/rear sump same as the jza70 but the main thing that gives it away is the A/C. The connectors are different on a Supra.
Skip
Re: 1JZ conversion problem - Sump fouling front universal joint Tue, 28 October 2003 04:45 Go to previous message
No thats not my engine, but yes my aircon compressor is identical, with the wierd connection.
Previous Topic:1JZ Engine mounts - urgent help needed!!!
Next Topic:ID'ing a 1JZ-GTE
Current Time: Fri Oct 23 21:57:18 UTC 2026
Total time taken to generate the page: 0.0054850578308105 seconds
