Toymods » Tech & Conversions » 4age 100kw in AE86
zecscott
adelaide
4age 100kw in AE86 Mon, 27 October 2003 01:16 Go to next message
if you already had a ae86 with a 4age 86kw bigport in it would it be an easy conversion to convert to a 100kw 4age? would it be worth it, or would you just stick with the 86kw?
._T_.
Re: 4age 100kw in AE86 Mon, 27 October 2003 23:11 Go to previous messageGo to next message
best mod woulds be to fit the 100kw bottom end to your existing motor
t
EVOSTi
cambo
      no
Re: 4age 100kw in AE86 Tue, 28 October 2003 06:00 Go to previous messageGo to next message
it would be very easy, you just gotta work out yourself whether you think its worth it or not, i would say probably not. skip the ge and go to the gze or better.
._T_.
Re: 4age 100kw in AE86 Tue, 28 October 2003 06:06 Go to previous messageGo to next message
a lot more fabrication/wiring and mods required. 100kw bottom end just bolts on!!!
t
FKN16V
NSW, East Coast
Re: 4age 100kw in AE86 Tue, 28 October 2003 07:06 Go to previous messageGo to next message
What sort of power/reliability should someone expect with the 100kw bottom and a bigport head.
EVOSTi
cambo
      no
Re: 4age 100kw in AE86 Tue, 28 October 2003 07:13 Go to previous messageGo to next message
yeah i know it will be much cheaper and easier, but is it worth the hassle for the minimal power gain?
pannelvan_screema
Campbelltown, NSW
Re: 4age 100kw in AE86 Tue, 28 October 2003 09:34 Go to previous messageGo to next message
thats what i was thinking go all or nothing.
i realy dont think its worth swapping a 88Kw for a 100Kw.
Im guessing it would put out about 90Kw as the extra power is in the 100Kw head port size and compression, would be more reliable cos of the oil cooled pistons and larger crank and gudgen.
Just go GZE!
CYA
EVOSTi
cambo
      no
Re: 4age 100kw in AE86 Tue, 28 October 2003 10:12 Go to previous messageGo to next message
yeah go gze! its fun i swear!!
adam
Re: 4age 100kw in AE86 Tue, 28 October 2003 11:41 Go to previous messageGo to next message
i'd personally go for the jap 97kw 4age. allready rwd. easy easy job, with the 100kw if u dont allready have a smallport rwd manifold made up u'll need one!
zecscott
adelaide
Re: 4age 100kw in AE86 Wed, 29 October 2003 23:06 Go to previous messageGo to next message
cheers fellas
the reason i asked about the 100KW is soley due to funds, don't worry id much prefer the gze no questions asked!! as for the jap 97kw 4age i haven't looked much but they are pretty hard to find in adelaide. but it was a question i had to ask, cheers fellas.
catch
Browndog
Re: 4age 100kw in AE86 Thu, 30 October 2003 04:08 Go to previous messageGo to next message
zecscott was the 4age put in or is it a stock 4age?
onejayzed
Re: 4age 100kw in AE86 Thu, 30 October 2003 05:33 Go to previous messageGo to next message
you'll prob pay the same for a good RWD 4AGE as you will a 4AGZE if you look hard enough.
there was a good rule of thumb i read somewhere that said
"don't bother with an engine conversion unless you're getting a minimum 25% power gain - if you're after less than that, build up your existing engine".
i thought that was a good idea anyways... Cool
Satoshi
Re: 4age 100kw in AE86 Thu, 30 October 2003 09:45 Go to previous message
what power would u get if u use 100kw bottom on a 86kw engine??
Previous Topic:Explaination of engine compression ratios??? Sorry, need to learn though.
Next Topic:ke20 brake upgrades?
Current Time: Wed Nov 4 02:58:38 UTC 2026
Total time taken to generate the page: 0.0088379383087158 seconds
