Toymods » Tech & Conversions » KE-55 convert from 4K to 2T-g
brad855
Gold Coast
icon10.gif  KE-55 convert from 4K to 2T-g Mon, 27 October 2003 10:27 Go to next message
I've found my engine the 2T-g with a compression of 210, i have the 2T-g cross member, now i need to know what i will need to get it passed engineering. I plan to upgrade the front brakes to vented disks MAYBE get the t-18 drums cause I've heard they are bigger and bolt on. The car will be stiffened and lowered. Also upgrade gearbox, to 5 spd. I've heard my Diff is Borg-warner and will be able to handle the extra power generated by the engine, and the tailshaft from what others have said will be also able to stand up. Just some help and guidence would be great thanks loads.
Brad
onejayzed
Re: KE-55 convert from 4K to 2T-g Tue, 28 October 2003 02:40 Go to previous messageGo to next message
your diff will be fine, as well as your tailshaft (with a new front yoke).
if the engine is heavier then yes you will prob need to upgrade the brakes, but remember you MAY not have to.
i am using a 1UZ-FE in my old datto and i don't have to upgrade the brakes (i'm just using soft pads with a lot of bite). the brake test was $200 from the engineer and was a complete emergency stop from 110kph and it passed with flying colours.
you may not need it for engineer's cert, but it's a good idea AFTER you get it licensed. if you start mucking with brakes you need to get certification that the swept volume is sufficient, the proportioning is okay etc etc. (ie not cheap).
just good pads and some stopping practice beforehand should see you thru....just.
brad855
Gold Coast
Re: KE-55 convert from 4K to 2T-g Tue, 28 October 2003 04:05 Go to previous messageGo to next message
thanks a lot onejayzed you helped a lot. Answered a few questions that i was worried about thanks.
Brad
[Updated on: Tue, 28 October 2003 04:13]
Re: KE-55 convert from 4K to 2T-g Tue, 28 October 2003 04:23 Go to previous messageGo to next message
I've got a 2TC in my KE55, not for performance, but because I had the parts lying round at the time Evil or Very Mad You can use the 2T engine and T50 5 speed no worries, but here's a few issues:
*You have to convert the clutch to hydraulic. Not hard, as the markings for the hole in the firewall are on the pedal box
*You can crowbar the 2T mounts onto the original 4K ones, but it's a tight fit, and the tailshaft is about an inch too long then. Ideally, modify the mounts slightly for a neater fit!
*The borg warner diff is utter crap, but will last OK if you don't treat it like I treat mine Evil or Very Mad I'm onto my 4th one now...
*I understand with 2TGs the carb is awful close to the brake cylinder, but this isn't really an issue
*The tailshaft will fit straight into the T50 box, but as I said it's a bit long if you don't screw with the engine mounts a bit
Hope I haven't missed anything! Very Happy
Re: KE-55 convert from 4K to 2T-g Tue, 28 October 2003 04:24 Go to previous messageGo to next message
Ahh, just noticed you say you have a proper 2TG crossmember - that should sort out all the mounting issues! Evil or Very Mad
brad855
Gold Coast
Re: KE-55 convert from 4K to 2T-g Tue, 28 October 2003 04:28 Go to previous messageGo to next message
Yeah mrshin that was a worry for me, but i have the 2t-g crossmember which should make life a little easier, but yeah i was worried about the fit. i've heard of the conversion done before in the coupe KE-35 just wanting to make sure i odn't have nasty suprises. thanks a lot for your reply. it too has helped me to no end Smile
EMP-2TG
Carlingford, Sydney
Re: KE-55 convert from 4K to 2T-g Tue, 28 October 2003 10:07 Go to previous messageGo to next message
ita all rather easy
and fits in well
i can email u a pic of my engine bay if u want
brad855
Gold Coast
Re: KE-55 convert from 4K to 2T-g Tue, 28 October 2003 11:43 Go to previous messageGo to next message
Yeah Josh if you could mail me that pic i would really appreciate it, apparently our engine bays are very similar in dimensions if not exact. thanks for ya help Smile any problems you had if any at all tell me about that would be great thanks again Smile
[Updated on: Tue, 28 October 2003 11:45]
EMP-2TG
Carlingford, Sydney
Re: KE-55 convert from 4K to 2T-g Tue, 28 October 2003 11:54 Go to previous messageGo to next message
yeah just shoot me your email address,
umm yeah its just as shin said really
i had 2tg mounts so my tailshaft was right
just all bolts up
brad855
Gold Coast
Re: KE-55 convert from 4K to 2T-g Tue, 28 October 2003 12:01 Go to previous messageGo to next message
It's bj_fowler18@hotmail.com thanks again for everyones help. I really appreciate it. Josh bud thanks for the pic, also how hard does your car pull now? what gearbox did you use?
Re: KE-55 convert from 4K to 2T-g Tue, 28 October 2003 22:17 Go to previous messageGo to next message
Just for the record, my car pulls like a rocking horse Very Happy
But then again it wasn't meant to do any good considering the cost!
brad855
Gold Coast
Re: KE-55 convert from 4K to 2T-g Tue, 28 October 2003 22:43 Go to previous messageGo to next message
Mrshin thats still sweet, it would go better than stock wouldn't it? Hopefulyl after i do some cam work and maybe post n polish and with the right extractors i can get a bit more power out of it. fingers crossed, i don't want anything lethal just something to get me from A to B a little faster than the 4k currently does. thanks again to all who have helped so far Smile
Re: KE-55 convert from 4K to 2T-g Tue, 28 October 2003 23:02 Go to previous message
Course it goes harder than stock - but a well buggered, stocky 2TC ain't gonna excite anyone... Some cams etc. in a 2TG should be a lot more exciting though Evil or Very Mad
Previous Topic:AE82 steering wheel onto AE86
Next Topic:New cars & breaking in engines
Current Time: Mon Oct 26 17:02:36 UTC 2026
Total time taken to generate the page: 0.10568904876709 seconds
