Classifieds » Miscellaneous » 1GGTE engine for reco
RobR
icon10.gif  1GGTE engine for reco Mon, 22 July 2002 16:28 Go to next message
1GGTE engine near complete with inlet ,exhaust manifolds needs recon $200 Rolling
DAMO
MELBOURNE
Re: 1GGTE engine for reco Mon, 22 July 2002 20:09 Go to previous messageGo to next message
IF IT HAS A WATER TO AIR INTERCOOLER I'LL TAKE IT.
RobR
Re: 1GGTE engine for reco Tue, 23 July 2002 04:12 Go to previous messageGo to next message
no sorry it doesnt...
Rattlehead
Re: 1GGTE engine for reco Tue, 23 July 2002 14:11 Go to previous messageGo to next message
Do you know what much it'll cost to recondition the engine?
RobR
Re: 1GGTE engine for reco Tue, 23 July 2002 14:22 Go to previous messageGo to next message
no idea...
the engine will suit someone who wants to modify a 1GGTE
the crank,rods were good...it didnt knock.
Rattlehead
Re: 1GGTE engine for reco Tue, 23 July 2002 19:21 Go to previous messageGo to next message
Is it out of an mk3 supra??
Come with ECU, wiring, sensor, turbo, cooler and everything??
RobR
Re: 1GGTE engine for reco Wed, 24 July 2002 01:32 Go to previous messageGo to next message
no it doesnt sorry...
it comes with zorst manifold,inlet manifold,only.
no loom,ecu,turbo's,dist.
nilezy
Re: 1GGTE engine for reco Sun, 28 July 2002 02:37 Go to previous messageGo to next message
Hey
Do you know if its the direct fire engine?? Why is it in need of a rebuild???
Cheers Nilezy
[Updated on: Sun, 28 July 2002 02:38]
RobR
Re: 1GGTE engine for reco Sun, 28 July 2002 05:28 Go to previous messageGo to next message
I'm not sure....it has no crank sencor or dist with it....
i can find out though...
why does it need a rebuild you ask?...its alittle smokey and was down on power...hence its done a few K's.
nilezy
Re: 1GGTE engine for reco Sun, 28 July 2002 09:09 Go to previous messageGo to next message
RobR
ok, cheers if you could find out if it was, that be great, as I could use a spare engine, or one I could build into a tough engine............Smile
Cheers Nilezy
RobR
Re: 1GGTE engine for reco Sun, 28 July 2002 15:23 Go to previous messageGo to next message
what is the difference with the dizzy and crankfire tpye?
Question Question
nilezy
Re: 1GGTE engine for reco Mon, 29 July 2002 01:46 Go to previous messageGo to next message
the main difference is that the dizzy has long leads, and a gap for which the spark, or eletrical charge has to cross. The direct fire type just has a sensor which gives a signal to the ecu to fire an igniter, which then triggers the coils to fire the spark plug. The coil is directly linked to the spark plug either by a short lead, or is directly over the spark plug, ie direct fire coils. The energy required to jump a spark across two gaps, like the dizzy type ingnition is greater, and if you use a dizzy, then you only have one coil, and one iginter usually, so this has more load on it, so to be able to precisely fire the spark plug, as to avoid detonation, etc.... is harder to control.
Another question.......... What is a Zorst Manifold?? is it a custom one??
Cheers Nilezy
RobR
Re: 1GGTE engine for reco Mon, 29 July 2002 10:29 Go to previous messageGo to next message
...i understand all that...however this engine WAS a dizzy type...from what i have been told all 1GGTE's were dizzy type..
i cant see what the difference is as this is a bare long engine
a "zorhst manifold" is slang for exhaust manifold..sangroper talk
lol
tuff_ra28
canberra
Re: 1GGTE engine for reco Sat, 03 August 2002 07:18 Go to previous message
do you have an altornator with all that aggte stuff.
if so would you sell it( if it works)
Previous Topic:100kw 4ag injectors
Next Topic:4 Sale Celica T50 G/Box +
Current Time: Mon Oct 26 18:31:08 UTC 2026
Total time taken to generate the page: 0.0085959434509277 seconds
