Toymods » Tech & Conversions » 3T GTE Fuel Injector????
_Ren_
icon5.gif  3T GTE Fuel Injector???? Tue, 28 October 2003 05:37 Go to next message
last week ive purchased a 3T GTE engine, and i found out it has some problem with the injector it doesnt work, stuck up all 4 of them, maybe some of you guys can help me up, is there any injector that i can replace with the old one? will it much better for bigger one or ill just stick to stock injector? what injector can be compatible with 3T GTE? Thanks!!!
threetee
Re: 3T GTE Fuel Injector???? Wed, 29 October 2003 11:58 Go to previous messageGo to next message
Yeh mate, when they've been sitting for a while they glog up something shocking - i can talk from experience, it cost a fortune to get mine cleaned but i've got a mate who put denso? spec Red tip (the ones wit the red ends) 13B injectors!
PLEASE let us know if i'm wrong !!
roger
Re: 3T GTE Fuel Injector???? Wed, 29 October 2003 20:15 Go to previous messageGo to next message
The 13B injectors you speek of are around 550cc I think. If you are running standard injection they may be a little big and you idle will suffer something shocking. If you are using after market injection then its all good after you tune it.
The standard injectors are around 295cc they are high impednce injectors with around 12-14 ohms. If you change make sure you get high impedence or run ballast resistors if you use low impedence injectors (Only applies to standard injection setup).
A possible swap for a similar size injectors is the 3sge, not sure of the injector style or impedence but the flow rate is about right.
To clean your injectors try this. Conect an efi pump up to the injectors. Instead of connecting to the fuel rail end conect to the manifold end. Run the pump and pulse the injector for 20 sec or so. Conect the pump to the fuel rail end of the injector and pulse the injector. Repeat until the injector sprays cleanly.
bootheman
in a box
Re: 3T GTE Fuel Injector???? Wed, 29 October 2003 22:56 Go to previous message
yer im after the same info.
so in short what injector lines and injectors are a good pair for a ct26 / 3tgte setup.
part numbers if posssible thanks.
Previous Topic:torque settings for 4age fly wheel
Next Topic:celica body kits
Current Time: Thu Oct 29 14:48:57 UTC 2026
Total time taken to generate the page: 0.037516832351685 seconds
