Toymods » Tech & Conversions » Oil leak from diff
BlackSupra
Oil leak from diff Tue, 28 October 2003 05:51 Go to next message
From behind what appears to be the drain plug in the center of the carrier cover i have an oil leak.
Is this a trivial rubber seal that has died, located behind the bolt or something worse?
Ta guys.
SupraPete
Re: Oil leak from diff Tue, 28 October 2003 06:05 Go to previous messageGo to next message
I got one too, same place I think.
Can you get a seal kit for a diff? I don't know much about them. Although it might be a good idea to change the fuel filter when the diff is out!
Jag7799
Re: Oil leak from diff Tue, 28 October 2003 07:00 Go to previous messageGo to next message
i got one too.. is your diff fluid red?
rob_RA40
c'town, NSW
Re: Oil leak from diff Tue, 28 October 2003 21:25 Go to previous messageGo to next message
from what i remember its not a rubber seal on the plug its just a steel washer.
you didnt happen to overfill the diff did u?
try going down to your local pick a part and taxing one from a wreck Cool
Jag7799
Re: Oil leak from diff Wed, 29 October 2003 04:01 Go to previous messageGo to next message
i want an ma61 diff... so ill get one when it becomes available
FKN16V
NSW, East Coast
Re: Oil leak from diff Wed, 29 October 2003 06:49 Go to previous messageGo to next message
I used a brass washer in my ae86 diff and gearbox, i think you'll find because brass is softer you'll get a tighter fit around the hole.
Goop that doesnt dry hard can also be used, just try not to get to much inside the hole.
Hope it helps
BlackSupra
Re: Oil leak from diff Wed, 29 October 2003 07:02 Go to previous messageGo to next message
havent filled it with anything and it hast been touched, its just started to leak recently
STR8 2.8
Re: Oil leak from diff Wed, 29 October 2003 07:03 Go to previous messageGo to next message
mayb u should try tightening it?
loose bolts tend to leak... Very Happy
BlackSupra
Re: Oil leak from diff Fri, 31 October 2003 05:20 Go to previous messageGo to next message
I had previously tried to tighten the bolt to this thread.
Any other help or ideas?
STR8 2.8
Re: Oil leak from diff Fri, 31 October 2003 09:35 Go to previous messageGo to next message
retap it, new bolt and some teflon tape...
supra1jz
Launceston, Tasmania
Re: Oil leak from diff Fri, 31 October 2003 11:28 Go to previous message
Just make sure it's coming from the centre bolt and not the breather at the top! Mine was leaking oil al over the place because the breather at the top was clogged up with grime. Cleaned breatherand problem solved!!!!
Previous Topic:CT20 to CT26 with GT4 intercooler
Next Topic:second hand turbos - what to look for
Current Time: Fri Oct 30 13:48:13 UTC 2026
Total time taken to generate the page: 0.0049219131469727 seconds
