Toymods » Tech & Conversions » Forced induction on a 20V 4AGE
Truzeno
Hunter Valley
Forced induction on a 20V 4AGE Wed, 29 October 2003 10:37 Go to next message
Does anyone know anything about this?
Have heard doesnt like the strain....
But I have just recently heard can be done.
SC or turbo?
Black or silvertop be better?
Even opinions.... anything about this issue.
Thanks!
[S.T.A.R.S]
ADELAIDE - Lenswood
Re: Forced induction on a 20V 4AGE Wed, 29 October 2003 11:08 Go to previous messageGo to next message
most ppl i have heard going to all that trouble use the early 4agze bottom with the 8.0:1 good for 30 psi.
truenosedan
Re: Forced induction on a 20V 4AGE Thu, 30 October 2003 02:40 Go to previous messageGo to next message
yeh i was gonna say, forced induction on a 20v, oh look at the time its already half past decompression o'clock
Truzeno
Hunter Valley
Re: Forced induction on a 20V 4AGE Thu, 30 October 2003 03:11 Go to previous messageGo to next message
No Message Body
[Updated on: Thu, 30 October 2003 05:21]
Truzeno
Hunter Valley
Re: Forced induction on a 20V 4AGE Thu, 30 October 2003 03:12 Go to previous messageGo to next message
No Message Body
[Updated on: Thu, 30 October 2003 05:27]
neat 20valve
Re: Forced induction on a 20V 4AGE Thu, 30 October 2003 03:22 Go to previous messageGo to next message
Come on people have u never seen drooln!!
ran stock motor on 6psi (turbo) got 290kw, just need a good computer for tuning,
stock 20v silver top 10.5-1 black top 11-1
gze - 8.5-1 & 8.9-1 (not sure if there is any others)
than as everyone else says there is the mighty
4agze bottom end takes a nice 25psi boost. Very Happy
slap on the 20valve head ond your boosting off your head like sam (4agte 20v close to 500hp)
so if your really going down this track get a gze bottom end, because no matter how much u tell me u will be happy with 290kw, when there is an easy way of getting another 150kw out of it i will not beleve u.
regards Craig
[Updated on: Thu, 30 October 2003 03:24]
onejayzed
Re: Forced induction on a 20V 4AGE Thu, 30 October 2003 05:37 Go to previous messageGo to next message
neat 20valve wrote on Thu, 30 October 2003 14:22
regards Craig
and it is pretty much as easy as that...gotta love the 4AG!!!
you could always use the 7E? 7F? 1.8L bottom end with GZE pistons and machined timing belt adjuster pulley (2.0mm) with the 20V head and a nice turbo with 20psi boost.
yum yum. Cool
Re: Forced induction on a 20V 4AGE Thu, 30 October 2003 06:03 Go to previous messageGo to next message
neat 20valve wrote on Thu, 30 October 2003 11:22
Gee, wish I'd run on that dyno, even the 21R-C would crack 100kW. Sorry, but at 6psi, even with one of the most efficient turbos known to man there is no way a 20v is going to produce 290kW.
neat 20valve
Re: Forced induction on a 20V 4AGE Thu, 30 October 2003 22:06 Go to previous messageGo to next message
justcallmefrank that is what i was told to me by word of mouth i know its not the same as a dyno sheet but this car does perform.
all i can say is try it and see what happens.
later Craig
Re: Forced induction on a 20V 4AGE Thu, 30 October 2003 22:25 Go to previous messageGo to next message
Putting a 20v head on a GZE bottom end isn't as simple as it sounds. Remember the GZE pistons have reliefs cut into them for 4 valves, which is likely to cause issues if you throw a 5-valve head into the mix!
Re: Forced induction on a 20V 4AGE Fri, 31 October 2003 00:23 Go to previous messageGo to next message
neat 20valve wrote on Fri, 31 October 2003 06:06
later Craig
I'm not denying thats what you've heard but even you have to realise it takes a lot more than 6psi on a small NA engine to see 290kW.
MR. 2
Parramatta
Re: Forced induction on a 20V 4AGE Fri, 31 October 2003 01:00 Go to previous messageGo to next message
i will second what justcallmefrank there is no way on 6 psi that a 1.6 motor will get those figures. Not even with a comp of 11.0 and then the turbo of a gt35 or some ridiculas size that wouldnt even spool up till 5 grand on a 1.6. who ever told u that figure is pulling you d#$k.
if some one tells u that again ask them for the dynbo sheet
Rex_Kelway
Re: Forced induction on a 20V 4AGE Fri, 31 October 2003 10:51 Go to previous messageGo to next message
I was trying to stay out of it, but alas i cannot.
I third the abovementioned crazy statement, not to mention its hypothetical fuel and tuning requirements.
A 290kw High Compression 20v 1.6 on less than 0.5bar, me thinks not Confused
Grega
melbourne.victoria.austra...
Re: Forced induction on a 20V 4AGE Fri, 31 October 2003 10:58 Go to previous message
maybe 290hp?
at the flywheel?
are you referring to the yellow ae86 with NOS that bent the tailshaft perhaps?
Previous Topic:second hand turbos - what to look for
Next Topic:AE82 twincam manual?
Current Time: Sun Oct 18 05:20:20 UTC 2026
Total time taken to generate the page: 0.012909889221191 seconds
