Toymods » Tech & Conversions » 4agze into a KE70
chrizer
4agze into a KE70 Thu, 30 October 2003 07:57 Go to next message
Hi guys
Im new, just wondering what would be needed for the conversion? Would i be able to use the standard diff in the KE70? Would the t50 gearbox be the best? etc?
Also what rough prices would i be looking at?
All comments welcome. Smile
coronamark2
Re: 4agze into a KE70 Thu, 30 October 2003 08:05 Go to previous messageGo to next message
click me
MR KE70
Parramatta
Re: 4agze into a KE70 Thu, 30 October 2003 08:37 Go to previous messageGo to next message
im asking the same question as you here too.
chrizer
Re: 4agze into a KE70 Thu, 30 October 2003 08:39 Go to previous messageGo to next message
not much info man? ive tried it already. surfed around and cant find much. Wanted to ask you guys because of your knowledge and maybe experience. Sad
EVOSTi
cambo
      no
Re: 4agze into a KE70 Thu, 30 October 2003 09:26 Go to previous messageGo to next message
whatever articles you can find on installing it into a sprinter apply to the ke70 as they are identicle.
you can use the diff and gearbox, but how are you gonna drive it? if you go easy they will be ok but if your gonna drive it hard you'll need something better. it all depends on how much you wanna spend and how much you can do yourself. if your determined to get it done just attack it and when you get stuck ask questions then. its pretty easy only a few niggly bits to worry bout but relatively easy as far as conversions go.
sleeka73
Re: 4agze into a KE70 Thu, 30 October 2003 09:52 Go to previous messageGo to next message
yeah what EVOSTi said, once u install the ae71 cross member, its pretty much the same as installing one into a sprinter, and there should be plenty articles for that floating around on the net.
chrizer
thanks EVOSTi
ive seen you talkin about ur 4agze in ur sprinter.
what do you think of it. does it perform well or up to ur expectations?
EVOSTi
cambo
      no
Re: 4agze into a KE70 Thu, 30 October 2003 10:17 Go to previous messageGo to next message
well i went from the 4ac to the gze so at first it was great, heaps fast. now im like neh, doesnt this thing go any faster?? Rolling Eyes but yeah pretty good. wouldnt mind slapping a big turbo on it one day Smile
LBack
Re: 4agze into a KE70 Mon, 03 November 2003 07:33 Go to previous messageGo to next message
EVOSTi, just wanted to asked if you installed the power steering and A/C in your 4agze setup. If yes, how did you go about the front stabilizer hitting the alternator?
my mechanic change my stock stabilizer with a stabilizer from a KP model but it is too low and always hitting the gutter whenever i parked the car.
peace...
EVOSTi
cambo
      no
Re: 4agze into a KE70 Mon, 03 November 2003 08:52 Go to previous messageGo to next message
car never had P/S, so never even considered it cause its light steering anyway.
A/C, i desperately wanted to keep but it was not to be. apart from the fact that the pulley is different and it would need some sort of custom mount (i was willing to do both) the compressor would have interfered with the extractors so it had to go.
everyone has the problem of the altenator hitting the sway bar, mine is mounted with some pipes sorta as brackets to move it further from the block. hard to explain but it clears it by about 10mm.
Henn
Rosanna, Melb
Re: 4agze into a KE70 Wed, 05 November 2003 03:22 Go to previous message
Due to pure luck, my alternator in its factory position clears the front swaybar by about 4-5mm. It's a 24mm Whiteline swaybar and everything else is stock.
You can always relocate the alternator, not much work in it, but if you are going to get a new swaybar anyway, look at one of these.
Hen
EDIT - Just saw this was in fact about KE70s, I was talking about a Sprinter.
[Updated on: Thu, 06 November 2003 09:20]
Previous Topic:KE30 rolla => more power
Next Topic:3SGE Beams? Any ideas where?
Current Time: Thu Nov 19 06:19:36 UTC 2026
Total time taken to generate the page: 0.0053629875183105 seconds
