Toymods » Tech & Conversions » Dialling in Solex carburettors.
SeptemberSquallIndustries
Dialling in Solex carburettors. Thu, 30 October 2003 10:40 Go to next message
Hi.
I'm running a pair of Mikini/Solex dual-throat carburettors on a 2T-G. I'm wondering how to go about dialing them in as best I can.
So far I've tried to, in order...
Set the idle screws full closed, then
Visually balanced the throttles (so both open simultaneously), then
Dial out the idle screws progressively, maintaining balance of approx +/- 180degrees of screw rotation (ie. half a complete turn)...
When the idle screw allows the car to start and idle, I've then tried to dial in the idle screws until the engine seems to run smooth (maintaining balance) with no real misfire or exhaust pop.
Then, I've found that adjusting the centre idle stop screw in and out will push the idle up at each end of its travel, so I've tried to hit that happy medium where the idle is lowest.
At this point the idle is around 1100RPM. Shouldn't it be lower than this?
Suggestions?
Astroboy007
Re: Dialling in Solex carburettors. Thu, 30 October 2003 20:44 Go to previous messageGo to next message
idle screws for basic setting as recommended by the toyota 2tg green handbook says 1.5 turns from full closed
onejayzed
Re: Dialling in Solex carburettors. Fri, 31 October 2003 06:30 Go to previous messageGo to next message
i would think that because of the engine's extra breathability with individual throats it would idle higher anyways? at least that's been my experience...? Confused
CelicaRA45
nth ringwood, Victoria
Re: Dialling in Solex carburettors. Fri, 31 October 2003 07:43 Go to previous messageGo to next message
do you have a carby balancer im in nth ringwood where are you bring it over i can balance them for you
Re: Dialling in Solex carburettors. Fri, 31 October 2003 13:00 Go to previous messageGo to next message
Car's not registered at the minute, my friend. Just trying to dial it in cleanly as a matter of academic interest. I'll get it dialled in properly before the car hits the road.
Thanks for your offer!
Jonny2TG
Tasmania
Re: Dialling in Solex carburettors. Sat, 01 November 2003 06:04 Go to previous messageGo to next message
You need to check and adjust fuel levels. Take one of the jet holders out of each carby when it is running, look down the hole at the fuel level. Higher makes it rich, lower makes it lean. There is a measurement in the book for base setting, then tune from that.
Factory idle spec says 1000rpm +- 100rpm.
If you have a flatspot, that is to do with the accelerator pumps and jets. Take carbs off engine and open the throttles to check, should do a wee of fuel from behind each throttle. Adjust the linkage so it works for all throttle opening movements.
freakincage_com
north brisbane
Re: Dialling in Solex carburettors. Fri, 07 November 2003 12:19 Go to previous messageGo to next message
hey dude my 2TG idles at 1500rpm so u dont have much trouble.....lol
icon13.gif  Re: Dialling in Solex carburettors. Fri, 07 November 2003 12:25 Go to previous messageGo to next message
"hey dude" just because your tuning is further out of spec than mine doesn't mean mine is okay. Rolling Eyes
gmsta27
Fl
Re: Dialling in Solex carburettors. Fri, 07 November 2003 19:22 Go to previous messageGo to next message
dealing with duel carb setup is not that difficult. You should make sure that there are no intake leaks. then that the correct pressure is available at the carbs. set the idle mixture screws about 1.5 to 2 turns out then ensure they are in synch. You can use a unisyn or other tool or use two vacum gauges. one hooked to each intake between the butterfly and the head. The gauges that are fluid dampened are the best type because they don't bounce so much. Then warm the car up and adjust the idle screws until the gauges read the same. once the carbs are in synch you can adjust the idle speed and then the idle mixture screws. To adjust the mixture turn the screw in until the rpms change then counting the number of turns out until the rpms start to drop off again ( rich ) divide the number of turns by two and turn in the screw that many of turns then go to the next screw. This will set the mixture at idle for the jets you have in the carbs. the jetting for the carbs should be done with other tests. I have a mikuni manual that explains this and I used it for my 2tg when i set it up. I tried to scan it but it took up too much memory. So, it you want a copy send me your mailing address and I will try to copy it and send it to you. I live stateside so it may take a day or two. Let me know . Be safe
Greg
Re: Dialling in Solex carburettors. Sat, 08 November 2003 03:13 Go to previous messageGo to next message
Greg, that'd be great. Thanks for taking the time to set out the process for me.
I'll PM you my address - if you have the time I'd love copies of whatever 2T-G / Mikuni related stuff you have.
freakincage_com
north brisbane
Re: Dialling in Solex carburettors. Sat, 08 November 2003 05:40 Go to previous message
hey dude i my last reply wasnt very usefull but i think u like this one i found this webpage to day
http://wow.atlasta.net/~mriluvu/oacdp/pdfs/solex.p df
its a online solex carb manual in pdf format so u need adobe acrobat to open it...
Previous Topic:4AC starter motor FWD to RWD
Next Topic:Help me with my central locking problems
Current Time: Wed Oct 21 09:59:46 UTC 2026
Total time taken to generate the page: 0.013653993606567 seconds
