Classifieds » Parts Wanted » 7m-ge SUPRA ecu
ed_ma61
Lost in the K hole
7m-ge SUPRA ecu Tue, 23 July 2002 05:05 Go to next message
as above really.
i REALLY REALLY need a 7m-ge ecu out of a mkiii supra. NOT out of the cressida (theyre different...betcha didnt know that!! No No No )
either that or i at least need an elctrical diagram from a cressida.
ed
ed_ma61
Lost in the K hole
Re: 7m-ge SUPRA ecu Tue, 23 July 2002 13:05 Go to previous messageGo to next message
bump
stevevp
Brisbane Qld
Re: 7m-ge SUPRA ecu Wed, 24 July 2002 04:21 Go to previous messageGo to next message
Ed,
Dont forget the supras ran low impedance injectors and the late cressida's are high impedance, don't want you to fry an ecu Smile
ed_ma61
Lost in the K hole
Re: 7m-ge SUPRA ecu Wed, 24 July 2002 07:48 Go to previous messageGo to next message
thanks steve.
gotta remember...although the supra ran low impedance injectors, they also run a resitor in series in the loom after each injector to bring total impedance up.
you wouldnt happen to know whether the late cressida (91)ecu is capable of operating the TVIS (ACIS) manifold butterfly as found in the earlier supras?? cant find it on the wiring diagram, but there are some unused pins there.... ideas??
how do you find the performance of the n/a cressida (im assuming you have one??)??
ed
[Updated on: Wed, 24 July 2002 07:50]
stevevp
Brisbane Qld
Re: 7m-ge SUPRA ecu Wed, 24 July 2002 11:58 Go to previous messageGo to next message
You assume correctly, 142kw isn't bad for a normally aspirated car. Although I am planning on a 7mgte conversion, I have the parts but not the time at present.
as for the tvis, I think someone is pulling your leg. the Y pipe is just an air connector between the throttle body and the manifold, as far as I can see it just give some extra length and volume to the manifold, and should theoretically increase bottom end torque.
ed_ma61
Lost in the K hole
Re: 7m-ge SUPRA ecu Wed, 24 July 2002 12:51 Go to previous messageGo to next message
steve, no, the tvis in the supra is a reality. the ecu opens a vsv to run a butterfly in the manifold at rpms over 4200 and 2/3 throttle.
the supra 7m ecu has a pinout for it, the cressida one doesnt have a pin labled (obviously) but has spare (and functional) pins on the board.
ed
Re: 7m-ge SUPRA ecu Fri, 26 July 2002 11:18 Go to previous messageGo to next message
I have an auto 7M-GTE ECU.... does that help?
ed_ma61
Lost in the K hole
Re: 7m-ge SUPRA ecu Fri, 26 July 2002 11:38 Go to previous messageGo to next message
nah, thanks anyway mate. going to run with the cressida ecu, and make my own circuit box to run the rest. gte ecu wouldnt work either anyway No No No
ed
Re: 7m-ge SUPRA ecu Fri, 26 July 2002 12:23 Go to previous messageGo to next message
How much for that 7MGTE ECU norbie?
Re: 7m-ge SUPRA ecu Fri, 26 July 2002 13:13 Go to previous messageGo to next message
$100?
Re: 7m-ge SUPRA ecu Fri, 26 July 2002 14:06 Go to previous message
Done. I'll email you.
Previous Topic:3TGTE injectors
Next Topic:still want RA60 bonnet badge
Current Time: Thu Oct 29 10:03:53 UTC 2026
Total time taken to generate the page: 0.0050117969512939 seconds
