Toymods » Tech & Conversions » Popping Sounds...
rebbot
Crawley, WA
Popping Sounds... Fri, 31 October 2003 03:47 Go to next message
Hiya GuyS,
After a major service on my car a few days back, I realised that there are popping sounds upon turning off the engine and the turbo timer comes into place...so I decided to sit sit in the car for a little while yesterday and confirmed it Sad Sad Sad
Anybody knows what wrong? Its a mk3 ga70 supra...
Cheers & thanks for any help!
Danners
Central Coast, NSW
Re: Popping Sounds... Fri, 31 October 2003 04:02 Go to previous messageGo to next message
Where in the car are the noises coming from?
If it only happens when the turbo timer is on i wouldn't expect it to be a problem. When i turn my car off the idle on my car gets slightly higher because none of the ancillaries are on anymore, this sometimes makes a bit of a burbling noise out of the exhaust while its idling
Dan
rebbot
Crawley, WA
Re: Popping Sounds... Fri, 31 October 2003 04:05 Go to previous messageGo to next message
Yeah They seem to be comming from the exhaust though...and the car kinda shakes a bit with every pop...Not sure if it is normal though as I did not have such a problem before...it only occured after my car have its servicing done...damnit~~~ Crying or Very Sad Crying or Very Sad Crying or Very Sad
ed_ma61
Lost in the K hole
Re: Popping Sounds... Fri, 31 October 2003 04:07 Go to previous messageGo to next message
sounds like a poor idle
risch, missing, bad timing, vac leak
Danners
Central Coast, NSW
Re: Popping Sounds... Fri, 31 October 2003 04:08 Go to previous messageGo to next message
Could be a dodgy spark plug lead?? I would check all of the connections to make sure that they've all been put back on properly. I did that once on a previous car, the spark was arching (spelling?) on another piece of metal in the car intermittantly causing to run on 3 cylinders (this was a 4 cyl car) this in turn shook the hell out of it Laughing
i still don't get why this only happens when the turbo timer is running
If you leave the car in neutral and just idling does the popping noise still occur?
Dan
[Updated on: Fri, 31 October 2003 04:11]
rebbot
Crawley, WA
Re: Popping Sounds... Fri, 31 October 2003 04:53 Go to previous messageGo to next message
ed_ma61: But all this happenning when I just did my service? Confused
It kinda feels like it only happens during the time when I turn off the engine mebbe later I should start up my car and let it idle in neutral and see wat happens...
Thanks guys for the advice so far anyway! Really appreciated!
ed_ma61
Lost in the K hole
Re: Popping Sounds... Fri, 31 October 2003 06:28 Go to previous messageGo to next message
a 'service' is a sure time for something to go wrong - you fiddle with things, and things go a little berko afterwards Razz
id recommend just letting it idle when warm, and sit and have a listen
rebbot
Crawley, WA
Re: Popping Sounds... Fri, 31 October 2003 17:42 Go to previous messageGo to next message
Yup yup, checked it out...the popping sounds only do occur during when the turbo timer comes on...mebbe Danners Its like what you say the burbling sounds the exhaust makes~~~HmMmMmM Kinda feels weird never had this problem before though... Sad
Mr DOHC
Re: Popping Sounds... Sat, 01 November 2003 02:51 Go to previous messageGo to next message
maybe for that split second when the primary ignition system {key in barrel} is cut off and the timer takes over, 1 or 2 sparks may miss going to their cylinders and thats raw fuel being dumped onto the nice hot exhaust turbine and lighting up
maybe, dunno Confused
Re: Popping Sounds... Sat, 01 November 2003 03:47 Go to previous messageGo to next message
my timer sits between the ign switch and engine electrics
the ign switch merely drives the timer so there's never a time at which there is no power to the ignition - unless the timer says "XX seconds have passed, turn off engine".
sounds like your timer is not wired up correctly?
charles.
rebbot
Crawley, WA
Re: Popping Sounds... Sat, 01 November 2003 17:25 Go to previous message
YeaH WiLL Be Getting My car Down to the workshop First Thing Monday Morning...Hope I can sort some stuff out man~~~ Very Happy Very Happy Very Happy
Previous Topic:corolla 4age wiring diagram
Next Topic:I'm in need of a Cressida guru...
Current Time: Sat Nov 21 01:43:25 UTC 2026
Total time taken to generate the page: 0.0090041160583496 seconds
