Toymods » Tech & Conversions » 4.3 diff centre for ta22
danielc
4.3 diff centre for ta22 Fri, 31 October 2003 15:16 Go to next message
any ideas what i could get a 4.3 diff centre out of to go into an early ta22? and are the early and late ta22 diffs the same?
._T_.
Re: 4.3 diff centre for ta22 Fri, 31 October 2003 21:55 Go to previous messageGo to next message
they are 6.7". of course finding a ae86 4age diff might be a tad hard... try a ms60 type crown.
T
CLG
Perth, Western Australia
Re: 4.3 diff centre for ta22 Sat, 01 November 2003 00:16 Go to previous messageGo to next message
MS60's are F series (7.5"). Your TA22 Celica will either have a D or T series diff, you can check this buy looking at the data plate in the engine bay. Next to the trans (T50 if it's a manual) stamp, there will be a diff code staring in either D or T. Some Celicas came with an optional 4.3 fitted, however these are very uncommon. Your best bet would be to find a set of gear from a Sprinter as T has stated, however if you buy the whole centre, beware that they are not a direct swap, there are some mounting bolt differences in terms of length of studs. You'll need to ask someone as to the compatibility of using a T series ring set, in a D series housing, it may need shimming due to its smaller (minutely) housing.
._T_.
Re: 4.3 diff centre for ta22 Sat, 01 November 2003 01:53 Go to previous messageGo to next message
i'm sure i had a 4.3:1 6.7 from a ms 60. could have been an ms45/55 now that i think about it though...
T
danielc
Re: 4.3 diff centre for ta22 Sat, 01 November 2003 10:10 Go to previous message
its a 71 mod hasnt got the diff code on the data plate, im pretty sure its the same diff as in my old 74 mod which had a t series diff, the 71mod has a t50 box as well so im assuming itll b the same... so try and find a 4age sprinter diff or the crown diff, anthing else to try? i can change studs etc, no dramas, even if i can just change the crownwheel and pinion
Previous Topic:replace T03/4 on my 18R with a CT20?
Next Topic:Problem with front wheels
Current Time: Sat Nov 21 02:18:43 UTC 2026
Total time taken to generate the page: 0.0039851665496826 seconds
