Toymods » Tech & Conversions » 4AC Distributor Problem
tailz
icon9.gif  4AC Distributor Problem Fri, 31 October 2003 18:20 Go to next message
hey guyz i have a sprinter and i experienced something wierd when tightning my distributor bolt that locks the distributor from turning ...
everytime i tight the bolt up ... the engine starts to die ... if i losin it up the idle goes back to normal ... but if i leave it lose it starts to twist into advanced ... so yeah what should i do ??
and also my distributor is leaking ... i dont know if itz the lose bolt thatz making it leak or just my O-Ring needs changing but i cant run the car while the bolt is tight to secure the distributor from turning back to advance ...
any help would be greatly appreciated ...
cheers ...
Scorpion
Menai area of Sydney
Re: 4AC Distributor Problem Fri, 31 October 2003 20:27 Go to previous messageGo to next message
Sounds like the body of the distributor is moving slightly as you tighten and therefore changing the timing slightly. Not an uncommon problem if this is the case. Try putting a washer under the bolt or smooth the underside of the head of the bolt so it doesnt catch on the distributor. Washer might be easier.
CLG
Perth, Western Australia
Re: 4AC Distributor Problem Sat, 01 November 2003 00:20 Go to previous messageGo to next message
Yep, sounds like some form of shaft play. If you can't rectify the situation, replace the dizzy with an electronic ignition unit from one of the front wheel drive Corollas.
tailz
Re: 4AC Distributor Problem Sun, 02 November 2003 06:01 Go to previous message
ahhh thanks guyz ... im going to try those methods today and hope they work hehehe ...
cheers ...
Previous Topic:114.3mm 5stud conversion needed for ST162
Next Topic:1GGTE info and suggestions
Current Time: Sat Nov 21 00:29:40 UTC 2026
Total time taken to generate the page: 0.0046329498291016 seconds
