Toymods » Tech & Conversions » Cressida Fuel Pump Resistor
x3600
Cressida Fuel Pump Resistor Fri, 31 October 2003 22:21 Go to next message
I just intalled a 240SX/Silvia spec Walbro 255 fuel pump into my MX83. I was curious, with this new pump do I need to retain the factory fuel pump resistor? Do walbros run on straight 12v current?
Thank you.
Re: Cressida Fuel Pump Resistor Sat, 01 November 2003 00:41 Go to previous messageGo to next message
Apparently Walbros don't like to run with a resistor. Most of the MA70 guys bypass their resistor after doing the Walbro upgrade.
7M-Brisbane
Re: Cressida Fuel Pump Resistor Sat, 01 November 2003 06:40 Go to previous message
When I fitted the Walbro to my MA71 I retained the factory resistor to run the dual voltages as per the standard pump setup.
I had no problems with this.
However, a friend did exactly the same thing and you could tell when it was kicking from low to high voltage so he removed the resistor and it was fine.
If I was you.. I'd install it, see how it goes.. and if it becomes a problem then remove it!
Previous Topic:FWD: How strong are cast pistons with a good tune? Apparently strong enough
Next Topic:Whats the deal with non replaceable Uni joints?
Current Time: Mon Nov 23 06:30:53 UTC 2026
Total time taken to generate the page: 0.014657974243164 seconds
