Toymods » Tech & Conversions » MA61 Auto>Manual
Hirogen
Melbourne, Australia
      WTF is a jabber?
MA61 Auto>Manual Sat, 01 November 2003 07:32 Go to next message
In the process of pulling the box n stuff out of the donor car. The starter is being a prick, just cant seem to get to the bolts. Is this swap one of those, pull out the engine jobs, or is it possible to do while the engine in is still in the car?
Re: MA61 Auto>Manual Sat, 01 November 2003 07:45 Go to previous messageGo to next message
Possible to do with engine in car.
To get to the starter motor bolts use a couple long extensions to get the ratchet somewhere you can put some decent leverage on it. Also try using a 3/8 drive rather than a 1/2 inch - they just seem to get into tricky spots a bit better.
I accept the top starter motor bolt is tricky on the M series.
Cressida Supra
Re: MA61 Auto>Manual Sat, 01 November 2003 09:21 Go to previous messageGo to next message
bah, u should doing it on a cressida
the engine is 1-2" closer to the firewall!!
anyway, yeah, easy to do in car, for start motor bolts, use a couple of ring spanners linked together for more leverage and pull.
failing that, get under it behind the tyre and try from there with a rachet.
failing that, do what GT said and get about 6, 9" extension bars, and physically sit behind the gbox and go from there
Re: MA61 Auto>Manual Sun, 02 November 2003 01:34 Go to previous messageGo to next message
You should try getting at the starter bolts when you've put a 2JZ in an MA61... THEN you'd be complaining! Razz
Hirogen
      WTF is a jabber?
Re: MA61 Auto>Manual Sun, 02 November 2003 02:34 Go to previous message
Thanks Cressida-Supra, the extensions did the trick. Had to hold the bolt too which was a pain. Now its out, now the fun comes of getting into the other car.
Previous Topic:Dummie's Guide to Supercharging
Next Topic:water from back of my MX83
Current Time: Sat Nov 21 00:13:14 UTC 2026
Total time taken to generate the page: 0.0080218315124512 seconds
