Toymods » Tech & Conversions » HELP?? Head gasket?
turbokid
HELP?? Head gasket? Tue, 23 July 2002 10:06 Go to next message
hey i need your help urgently.
is condensation coming out the exhaust of a 7mge likely to be a head gasket problem?? any suggestions? the engine does have extractors and a full exhaust system.
DannyGT4
Toymods Board Member
Re: HELP?? Head gasket? Tue, 23 July 2002 11:47 Go to previous messageGo to next message
lol certainly could be a sign but could also be alot of things Smile
compression & leak-down tests are a better indicator
Smile
Re: HELP?? Head gasket? Wed, 24 July 2002 00:40 Go to previous messageGo to next message
Don't forget to look for bubbles in the radiator! And does it use any water? Any water in the oil? Hard to start/misses on 1 or 2 pots for a few seconds after you start it?
Allan
Re: HELP?? Head gasket? Wed, 24 July 2002 01:07 Go to previous messageGo to next message
goto a tuneing place get them to stick the gas analiser in the radiator thay will soon tell you if ya have a problem.
Allan
Grega
melbourne.victoria.austra...
Re: HELP?? Head gasket? Wed, 24 July 2002 02:08 Go to previous messageGo to next message
might pay to check the color of your oil and water, if its white and milky then you have issues..
turbokid
Re: HELP?? Head gasket? Thu, 25 July 2002 08:43 Go to previous messageGo to next message
thanks fellas
turns out the engine is fine
some idiot probably hosed up the exhaust
i got the racq report back today. the engine is the least of probs. the smoke was from rich air/fuel ratios i think.
SUPRAGTE
North Sydney
Re: HELP?? Head gasket? Fri, 26 July 2002 05:33 Go to previous message
Your very lucky,
usually moisture comming from the exhaust on a hot car(exhuast must be warm to stop confusion with condensate) it is a blown head gasket. Usually it smells sweet because of the glycol evaporating from you engine coolant.
Previous Topic:Series 1 RX7 Brake Upgrade
Next Topic:THANKS.
Current Time: Sun Nov 1 19:55:55 UTC 2026
Total time taken to generate the page: 0.0159010887146 seconds
