Toymods » Tech & Conversions » why is my radiator always dehydrate?
Satoshi
why is my radiator always dehydrate? Sat, 01 November 2003 13:09 Go to next message
anyone knows?
it dehydrates like everyweek....
SPEEDCORE
GoldCoast/Brisbane
Re: why is my radiator always dehydrate? Sat, 01 November 2003 13:23 Go to previous messageGo to next message
One word GATORADE! Very Happy
Seriously though have you checked your hoses and radiator?? At worst....... pray that it's not a headgasket...... unless it is a 4A-C.. then don't refill it and fasttrack a conversion
Satoshi
Re: why is my radiator always dehydrate? Sat, 01 November 2003 13:30 Go to previous messageGo to next message
spot on...its a 4ac..yes..there's blowing white smokes and during idling...the oil gauge goes down and the engine feels like dying...
need some rev rev to keep the engine staying good..if not..the whole engine feeels like shaking
SPEEDCORE
GoldCoast/Brisbane
Re: why is my radiator always dehydrate? Sat, 01 November 2003 13:41 Go to previous messageGo to next message
Sounds like the 4A-C is slowly going to the grave man..........
Satoshi
Re: why is my radiator always dehydrate? Sat, 01 November 2003 13:54 Go to previous messageGo to next message
Shocked where's the nearest place to get coffin?
btw...is it worth to change the headgasket and use back the 4ac?
SPEEDCORE
GoldCoast/Brisbane
Re: why is my radiator always dehydrate? Sat, 01 November 2003 14:39 Go to previous messageGo to next message
Well this is IF it is the H/G blown...
I think it all comes down to how much $$$$ you can afford to spend on your car ATM. If a conversion cannot be afforded ATM, then get the H/G replaced as cheap as possible..... this is if the rest of the engine is ok and nothing else need to be fixed replaced or repaired.... not many 4A-C's around like this Razz always better to have a car that goes than a car that doesn't, right?
You would have to weigh up the cost of a new H/G (again if it is the H/G), and a not too expensive conversion...... Bluetop, 100kw for example.
Classique71
Colac, Victoria
Re: why is my radiator always dehydrate? Sun, 02 November 2003 02:51 Go to previous messageGo to next message
your 4ac shouldnt pop "e" 's then :)but seriously sounds like a headgaskeys gunna go POP!
CLG
Perth, Western Australia
Re: why is my radiator always dehydrate? Sun, 02 November 2003 02:59 Go to previous messageGo to next message
Most radiator shops do a free colour dye test to check for combustion gasses in the radiator, this is the quickest cheapest way to find out if it is the head gasket. If it is and you can't afford to repair or replace it at the moment, get a bottle of "Bars Leaks", and follow the intructions.
I once ran a 6 cylinder Falcon motor with a blown head gasket on that stuff for another 6 months without drama. Naturally, if the blown head gasket is too far past it, nothing will help you, aside from repair where you will be looking at a bill of over $300.
Satoshi
Re: why is my radiator always dehydrate? Sun, 02 November 2003 03:08 Go to previous messageGo to next message
what's "Bars Leaks" and where can i get em for?
my 4ac has been raving too much...i guess he's too old to survive for anytime longer..
for 300 bucks..i'm just a mile away from paying off for an 4ag engine..
CLG
Re: why is my radiator always dehydrate? Sun, 02 November 2003 07:47 Go to previous messageGo to next message
Barsleak is an internal leak sealer you add to your radiator water. You can get it from any auto store.
mrsmart
Melbourne Eastern Suburbs
Re: why is my radiator always dehydrate? Sun, 02 November 2003 09:33 Go to previous messageGo to next message
Shelled eggs do just as well as bars leaks... try it!
Satoshi
Re: why is my radiator always dehydrate? Sun, 02 November 2003 10:26 Go to previous messageGo to next message
alright..thanks guys..
so if it's my headgasket..it will at least help my headgasket to live longer a little bit?
Scorpion
Menai area of Sydney
Re: why is my radiator always dehydrate? Sun, 02 November 2003 10:39 Go to previous messageGo to next message
Before you start using Bars Leaks, get a radiator place or a mechanic to do a pressure test on your cooling system. I used to lose water out of my 4AC and a pressure test showed up a loose hose hose fitting down near the water pump where it's hard to see normally. At least then you'll know what you are treating - or better still you might have an easy fix. Very Happy
Satoshi
Re: why is my radiator always dehydrate? Sun, 02 November 2003 14:37 Go to previous messageGo to next message
how much labour they will charge for a cooling system pressure test?
SPEEDCORE
GoldCoast/Brisbane
Re: why is my radiator always dehydrate? Sun, 02 November 2003 14:43 Go to previous messageGo to next message
Classique71 wrote on Sun, 02 November 2003 13:51
your 4ac shouldnt pop "e" 's then Smile
What exactly do you mean by this???
Scorpion
Re: why is my radiator always dehydrate? Sun, 02 November 2003 21:42 Go to previous messageGo to next message
Shouldn't cost much - maybe equivalent of a couple of bottles of Bars Leaks. All they do is connect a pump onto where your radiator goes and pump some air into the radiator to pressurise the system - at least that's what they used to do. Then they have a look around your engine to look for external water leaks - probably 15 minutes work. Maybe some of the motor mechanics out there can give you a better idea of costs etc. - or go to a service workshop and ask - won't take long to find out, they should be able to tell you off the top of their head.
CLG
Re: why is my radiator always dehydrate? Mon, 03 November 2003 06:21 Go to previous messageGo to next message
A good radiator shop will do a pressure test for free too!
Alchemist
Re: why is my radiator always dehydrate? Mon, 03 November 2003 08:57 Go to previous messageGo to next message
If your buying a car and its got bars leaks in the radiator, dont buy it Razz But it will keep your car going just that bit longer.
Alch
Satoshi
Re: why is my radiator always dehydrate? Tue, 04 November 2003 11:21 Go to previous messageGo to next message
bought Bars Leak..used it..and it seems quite good..
engine is less freaking out..
hope it will last a few months..
thanks guys for the help!
FKN16V
NSW, East Coast
Re: why is my radiator always dehydrate? Tue, 04 November 2003 13:30 Go to previous message
Let the motor sit over night, remove each spark plug one at a time and inspect plug and cylinder for water.
When my 4ac wasnt running right my mechanic at the time removed number one spark plug, gave the motor a quick crank and it shot water about 6 foot away from the car.
That the worst blown headgasket ive ever heard about.
Cost you nothing and it takes no time at all.
If it reveales nothing get someone in the no to have a look at it.
A sniffer dog will find any gases in the radiator. Most head or radiator shops will be able to do it for you.
Previous Topic:HKS T451
Next Topic:7m-gte in 83 st141 corona???
Current Time: Mon Nov 23 01:48:49 UTC 2026
Total time taken to generate the page: 0.023115158081055 seconds
