Toymods » Tech & Conversions » ATF question
manipulate
ATF question Sun, 02 November 2003 04:21 Go to next message
Hey all
I know with engine oils.....if a cars engine specs SJ....its ok to go up to SK or SL.....its ok to go up but not down
is that the same with ATF ?
for example....the celica takes a type F (from memory)....and im just wondering if u can go up ie: Type T....??? or u must get the specified
Thanx
Mani
clubagreenie
1st street on the right
Re: ATF question Sun, 02 November 2003 21:01 Go to previous messageGo to next message
I know that the same types you can upspec (dextron 1 to 2 or 3 etc) is GM. Type F is ford (early) late is Mercon, if mercon isn't available use dex 2. Chrysley specs Mopar and dex 2 is a substitute but mopar can't be sub'd for mercon (go figure). Toyota often specs type T (in later models) without substitution).
Amsoil make a "universal" ATF, but you will pay dearly for it like all their stuff. But it matches the following,
GM;  Dexron II, Dexron III, GM 6297M, GM 6417M
Ford;  Mercon, Mercon V, M2C 163-A2, M2C 202B
Chrysler;  ATF+ thru ATF+4, MS 7176E, MS 9602D
Allison;  C-3, C-4,  Caterpillar;  TO-2, TO-3,  Voith Commercial,  Opel and GM Strasbourg
Power Steering Recommending ATF,  Multiple Industrial Hydraulics
AMSOIL ATF can also replace any of the following manufacturer brand name fluids:
AGCO/Deutz-Allis/White; Power Fluid 411
Nissan, Hyundai, Mitsubishi Diamond SP,  Porshe
AND will interchange with Toyota Type T and T IV (4)
But it's $7-80 US per quart, not cheap.
Toyota's fluid seems to be one of the Highly Friction Modified fluids, which there is an additive for to bring dex 3 or higher up to HFM spec and can be used in these apps.
juzzo84
Hornsby, N.S.W
Re: ATF question Sun, 02 November 2003 21:12 Go to previous messageGo to next message
just drop some dextron 2 into her and see what she does!! Smile
manipulate
Re: ATF question Thu, 06 November 2003 08:44 Go to previous message
Greenie thanx for that
Yeah i got some Dex 3 which should be right
Thanx
Mani
Previous Topic:Anti-lag setup??
Next Topic:AE82 Hatch external mods!
Current Time: Thu Nov 19 16:36:02 UTC 2026
Total time taken to generate the page: 0.11838603019714 seconds
