Toymods » Tech & Conversions » Sprinter with 7" rims and a +25mm offset
gabe
Sprinter with 7" rims and a +25mm offset Mon, 03 November 2003 11:32 Go to next message
I am contemplating buying some rims for my sprinter and the fronts have an offset of +25mm.
The rims are 7" wide.
Will handling suffer....? Whats the best offset to look for....? Will the tyres rub on my struts....?
Any other info will be appreciated.....
bootheman
in a box
Re: Sprinter with 7" rims and a +25mm offset Mon, 03 November 2003 11:38 Go to previous messageGo to next message
i ran 17x7 on mine with about the same offset okay but rubs around tight coriners and a bitch when parking..
other then that fine, but watch your dif and your gearbox Laughing
gabe
Re: Sprinter with 7" rims and a +25mm offset Mon, 03 November 2003 11:41 Go to previous messageGo to next message
bootheman wrote on Mon, 03 November 2003 19:38
Damn quick reply. This bit went right over my head tho....
bootheman
in a box
Re: Sprinter with 7" rims and a +25mm offset Mon, 03 November 2003 11:50 Go to previous messageGo to next message
well due to now the size and the weight of the rims, u are gona do damgee, i did when i came on boost the dif and tail shaft would snap.
run some shitful tyres cos thier alot cheaper thehn a dif or a gearbox
CLG
Perth, Western Australia
Re: Sprinter with 7" rims and a +25mm offset Mon, 03 November 2003 14:59 Go to previous messageGo to next message
Thats a bit of a defeatist attitude, ..., at 25mm on a 7" rim, they're gonna rub! That offset is more appropriate for a 5.5-6" rim
Ko Ko
Re: Sprinter with 7" rims and a +25mm offset Mon, 03 November 2003 21:22 Go to previous messageGo to next message
what will happen to the diff and the gearbox fitting those wheels i just don't understand
Eddy
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: Sprinter with 7" rims and a +25mm offset Tue, 04 November 2003 00:49 Go to previous messageGo to next message
the diff and the gearbox thing is a load of crap spilled by ill informed idiots.
im not sure if they are reffering to the 7 inch wide rim? in which case they would be running 195 wide rubber... many sprinters do this including mine without blowing diffs or gearboxes
im not sure if they are reffering to the +25 offset which increases track? well i have more track front and rear on my car then most ae86's owners do and guess what.. no diffs or gearboxes blown....
Jag7799
Re: Sprinter with 7" rims and a +25mm offset Tue, 04 November 2003 01:08 Go to previous messageGo to next message
Id just like to add my 2c's.. now i dont have a sprinter, ive got a gz10 soarer that has the same offset as old sprinters (+20)... ive got 17x7's on it and it doesent rub or scrape no matter what i do... and im running 235/45/r17 tyres aswell
dunno if thats any help
[Updated on: Tue, 04 November 2003 01:10]
CLG
Re: Sprinter with 7" rims and a +25mm offset Tue, 04 November 2003 06:12 Go to previous messageGo to next message
Standard Sprinter offset is 27mm. My 7" wide rims with 205/45/16 tyres fit on my Sprinter with no worries. The offset on these rims is 17mm negative (ie, the mounting face is closer to the face of the wheel than the back).
Sprinter
Re: Sprinter with 7" rims and a +25mm offset Tue, 04 November 2003 06:18 Go to previous messageGo to next message
I ran 16x7's with 25pos offset. Only a slight rub against the strut tower (thats not the strut but the body). I also ran 205/45 tyres.
I havent had any wheel induced problems with the diff or GB by running the larger wheels. My problems were a result of the torque I was putting through them and the hard life they had lived Smile
Just my 2c
Denis
CLG
Re: Sprinter with 7" rims and a +25mm offset Tue, 04 November 2003 06:29 Go to previous messageGo to next message
OK, clarification on offset. My understanding is positive offset occurs when the wheel mounting face is short of the median point of the wheel, ie the wheel has a greater percentage of the wheel in front of the mounting face than behind, and vice versa for negative offset.
My reason for taking this approach is, we all know FWD cars run large negative offsets by design (usually around -40mm) and their mounting faces are pushed out to the outside edge of the wheel.
By error of assumption, everyone assumes a RWD runs positive offset as that is what everyone says, but the fact is, most RWD still run negative offset, just less so than FWD cars. To see true positive offset on factory wheels, look for something like a Porsche rim, these run positive offset from the factory, and have deep dishes in the rim due to this factor.
Sprinter
Re: Sprinter with 7" rims and a +25mm offset Tue, 04 November 2003 06:37 Go to previous messageGo to next message
I thik you have it back to front. Positive offset is towards the outside edge of the rim, negative offset is back towards the inside edge of the rim. E.g. a "deep dish" rim runs low positive (10 - 0) or negative offsets.
For example, the stad Aus sprinter wheel is 13x5 with 27pos offset. If you measure from the back of the rim to the mounting face you will cross the middle of the rim and travel a further 27mm.
FWD's usually run large POSITIVE offset rims - 30mm positive and greater.
HTH
Denis
CLG
Re: Sprinter with 7" rims and a +25mm offset Tue, 04 November 2003 07:46 Go to previous messageGo to next message
I can find definitions for both types of description. I have a feeling it may be a European/American definition difference, with my definition matching the American definitions. Can anyone else shed light on this, as it regulalrly pops up in my conversations?
gabe
Re: Sprinter with 7" rims and a +25mm offset Tue, 04 November 2003 08:15 Go to previous messageGo to next message
This is a brilliant link.........
http://www.chris-longhurst.com/carbibles/index.htm l?menu.html&tyre_bible.html
So will my tyres rub or not........??
Rex_Kelway
Re: Sprinter with 7" rims and a +25mm offset Tue, 04 November 2003 08:21 Go to previous messageGo to next message
Hey buddy,
From experience i can say that 15 x 6.5 with 205s @ +20mm works very well.
The offset is not enough to do any major damage, they fill out the guards wonderfully and actually feel easier to turn without any hint of contact at lock or on bumps. Also puts a fair amount of rubber on the road
Clint knows this too Very Happy
PS sorry about the foto's clint i cant find the cameras bastard connection cable Mad.
Dodgy_Haro
Re: Sprinter with 7" rims and a +25mm offset Tue, 04 November 2003 09:48 Go to previous messageGo to next message
For 7" wide rims, you will need zero offset for a Sprinter. Any positive offset will make the wheel sit inward.
Why not try Datsun rims instead? They are guaranteed to fit with no probs:
http://users.tpg.com.au/adsl6ii7/Dat3.JPG
http://users.tpg.com.au/adsl6ii7/Dat4.JPG
[Updated on: Tue, 04 November 2003 09:50]
ae86drift
sydney.au
Re: Sprinter with 7" rims and a +25mm offset Tue, 04 November 2003 10:37 Go to previous messageGo to next message
http://members.ozemail.com.au/~givers/watanabe2.jpg
my rear wheels...14 x 7.5 -4 offset
JUST fits without scrub.. and i mean JUST
[Updated on: Tue, 04 November 2003 10:41]
Simon-AE86
Banned user
Re: Sprinter with 7" rims and a +25mm offset Tue, 04 November 2003 10:44 Go to previous messageGo to next message
eeer daz, positive wheels stick OUT not in more, too much negitive offset and wheel/tyre hits struts or inner gaurd.
too much positive and u hit the outer gaurd.
Dodgy_Haro wrote on Tue, 04 November 2003 19:48
ae86drift
sydney.au
Re: Sprinter with 7" rims and a +25mm offset Tue, 04 November 2003 10:53 Go to previous messageGo to next message
err simmo
u sure?
http://www.usacomp.com/Offset.htm
ae86drift
sydney.au
Re: Sprinter with 7" rims and a +25mm offset Tue, 04 November 2003 10:59 Go to previous messageGo to next message
Positive offset is how most factory wheels are designed. The wheel center is moves the wheel closer to the vehicle, therefore moving the tire closer to the vehicle, helping to tuck it under the fenderwell. This means the wheel rotates on its axis.
Negative offset is how most aftermarket wheels are designed. They move the center of the wheel away from the vehicle. Therefore, moving the tires away from the vehicle, and increasing the turning radius. Rather that spinning on its axis, it swings on its axis. There are several inherent flaws with this, while they may be unavoidable. Increasing the offset puts more leverage on the lugs, which means you can break them easier, but it also increases the stance of your vehicle to help keep it more stable. The swinging affect means more lift is needed to avoid rubbing.
Simon-AE86
Banned user
Re: Sprinter with 7" rims and a +25mm offset Tue, 04 November 2003 11:07 Go to previous messageGo to next message
now im confuised... the way i had it worked out was the total oposite to that.. i even have 5 sets of wheels down stairs in varying offsets ranging from -17 to +10 and the +10's stick RIGHT out the gaurds.. they are a 8 inch rim also.
Re: Sprinter with 7" rims and a +25mm offset Tue, 04 November 2003 11:18 Go to previous messageGo to next message
There is no difference in the way aftermarket wheels and factory wheels are measured, they are all measured as the distance between the centreline of the wheel and the mounting face.
In a positive offset the mounting face is towards the outside of the car, too big and you'll be rubbing the strut and too small (depending on the car and the width) it'll touch the guards.
In a negative offset the mounting face is towards the inside of the car, too big (in the negative direction) and you'll have the wheel rubbing on the guard.
ae86drift
sydney.au
Re: Sprinter with 7" rims and a +25mm offset Tue, 04 November 2003 11:22 Go to previous messageGo to next message
exactly
BOOOOOOOOYAH!
Wink
btw boys > working tech support sucks arse
gabe
Re: Sprinter with 7" rims and a +25mm offset Tue, 04 November 2003 11:49 Go to previous messageGo to next message
so +25 on a 7 inch rim is going to be too much. something closer to zero will be more appropriate....??
so front wheel drive cars actually have huge ammounts of positive offset....
Re: Sprinter with 7" rims and a +25mm offset Tue, 04 November 2003 11:51 Go to previous messageGo to next message
It would be too much on a Sprinter. FWD cars and new RWD cars usually have a large positive offset.
Jag7799
Re: Sprinter with 7" rims and a +25mm offset Tue, 04 November 2003 12:50 Go to previous messageGo to next message
as far as im aware your only meant to fit rims with same or larger offset then ur car
i.e if you have +20 offset then u can fit +25 rims.. and ur not meant to go the other way..
and i think the legal limit is adding 25 to ur offset
ALL new cars are positive offset
running around +40 somewhere
offset confuses me.. but thats some stuff that i know
Re: Sprinter with 7" rims and a +25mm offset Tue, 04 November 2003 12:53 Go to previous messageGo to next message
There is no rule with what your offset can be, providing you aren't interfering with the body work or suspension and you dont increase or decrease your track by a certain amount.
Jag7799
Re: Sprinter with 7" rims and a +25mm offset Tue, 04 November 2003 12:57 Go to previous messageGo to next message
its all so fucking confusing
Dodgy_Haro
Re: Sprinter with 7" rims and a +25mm offset Tue, 04 November 2003 13:38 Go to previous messageGo to next message
I've never had a measuring instrument but I believe for a Sprinter you're looking at somewhere between 12 to 15 for 6.5" wide rims. For 6" wide rims, something greater of 18 or so and for 7" wide rims, zero offset is ideal.
Not sure about 8" rims as you can hardly find those here.
Anything which has a positive offset of 30 and above is definitely a FWD wheel.
To answer the initial query of this thread (and as Simon said), the best way of finding a suitable alloy is to try the wheels on your car first before buying.
You may come across some which will fit and spin freely but still sit a little inward from the fender:
 http://users.tpg.com.au/adsl6ii7/Br2.JPG
However, there are rims which are dead giveaways as to whether they fit or not, like the 3 piece Enkei's in the sale section - 30 above positive offset meaning they are FWD wheels. On a Sprinter, did someone mention SPACERS? Rolling Eyes
[Updated on: Tue, 04 November 2003 13:39]
CLG
Re: Sprinter with 7" rims and a +25mm offset Tue, 04 November 2003 14:47 Go to previous messageGo to next message
gabe wrote on Tue, 04 November 2003 16:15
OK, regardless of offset definition, yes 25mm on a Sprinter will rub on the chassis rail, definately on the front, probably on the rear, and if the offset is the other way, definately on the guard.
My 16 x7's with 17mm fit in snugly, but I wouldn't want any more. I've also had 16x8's on a RA28 celica back end with an offset of 5mm and with 235/45's, the just squeezed in, but the guards were rolled quite tightly.
Dabbid
Yowie Bay, Sydney
Re: Sprinter with 7" rims and a +25mm offset Wed, 05 November 2003 11:16 Go to previous messageGo to next message
i thought wheels just had to be round?
i know mine are are the fit really well...
they even roll too!!
CLG
Re: Sprinter with 7" rims and a +25mm offset Thu, 06 November 2003 01:19 Go to previous messageGo to next message
Yep, I've tried em all, ..., triangles, squares, pentagons, hexagons, septagons, octagons, nonagons, decagons, ..., circular stuff works the best!
c2888
Re: Sprinter with 7" rims and a +25mm offset Thu, 06 November 2003 01:56 Go to previous messageGo to next message
Ideal offsets for a Sprinter, i've calculated these myself, they set the wheel up the same distance from the strut as stock.
Going either way 5mm won't change your clearance, but it may be the difference between fitting 185's or 195's
But they will fit, more important that you get the fronts correct otherwise you'll rub the strut and get some nasty handling.
Width Offset
5.5 +27
6.0 +20
6.5 +14
7.0 + 8
7.5 + 2
8.0 - 4
The factory Sprinter wheel has +27 offset, but for a 5 inch wide wheel.
Tarago's have a 5.5 inch wide rim with a +27 (the same wheel as a celica RA60 but i had a tarago so i'll refer to them as tarago wheels)
MA61 get the 7.0 inch wheel with +8 offset. These fit Sprinters and won't rub if you don't get overboard with rubber.
Daniel
[Updated on: Thu, 06 November 2003 02:52]
Re: Sprinter with 7" rims and a +25mm offset Thu, 06 November 2003 02:25 Go to previous messageGo to next message
Your offsets are back to front. Aside from that it looks to make sense.
c2888
Re: Sprinter with 7" rims and a +25mm offset Thu, 06 November 2003 02:55 Go to previous messageGo to next message
Amended, thanks for pointing it out, to many numbers in this head.
FKN16V
NSW, East Coast
Re: Sprinter with 7" rims and a +25mm offset Thu, 06 November 2003 04:58 Go to previous message
[quote title=c2888 wrote on Thu, 06 November 2003 12:56]
Width Offset
5.5 +27
6.0 +20
6.5 +14
7.0 + 8
7.5 + 2
8.0 - 4
Does this mean that these are the right figures.
Previous Topic:(Initial D) Evo misfiring racesystem... Explain if real.
Next Topic:ST162 pod filter
Current Time: Thu Nov 19 13:31:38 UTC 2026
Total time taken to generate the page: 0.061776161193848 seconds
