Toymods » General Car Talk » Idling.. Normal Or weird..?
SW20R
Idling.. Normal Or weird..? Fri, 17 May 2002 06:56 Go to next message
Hey guys im just waiting till monday for my tune up but i cant wait! hehehe
okay so i can start my baby up (see pic Smiley =
on a cold day.. and since the car atm is in the garage so its abit colder..
anyways when i fire her up she idles at about 2.8grand. 4A-Ges are louddddd!! 2" Exhaust, car in the garage with front and back roller doors open, Muffler on the ground hehehe (havent connected) after 2/3 Minutes she drops down to about 1.8k then another min she drops to 1.3k and rises to 1.8K and this just goes over and over like a broken record.. 1.3, 1.8, 1.3, 1.8 you get the pic.. i dont know if its my accelerator cable/peddle (this needs to be timed since its not responsive as playing with the cable in the engine bay reving it by hand)
So after about 4/5 Minutes the idle drops to 1.3K-1.8k.. but idles rough like a jerky carby..
the problems i think are
a)injectors dirty or something?
b)computer damaged?
ive followed the rollaboyz 20v and gze tutorials when first starting the car.. you let her alone rev freely to find where to idle? and i leaving alone long enough or did i interrupt her?
cheers guys!
[Updated on: Sat, 18 May 2002 02:09]
SXer
Re: Idling.. Normal Or weird..? Sat, 18 May 2002 08:50 Go to previous messageGo to next message
My 4A-GE (100kW) idles at 2k when it first starts bu then drops after its warmed up. I don't know how it works out whether it is hot or cold.
In your case could it be the O2 sensor? (if you haven't got the full exhaust yet?)
Monty
faulksy
Re: Idling.. Normal Or weird..? Sat, 18 May 2002 15:35 Go to previous messageGo to next message
definitely starts very high and does sound like a O2 sensor but also check that your coolant level is up. low coolant could explain the erractic idle.
SW20R
Re: Idling.. Normal Or weird..? Sat, 18 May 2002 15:41 Go to previous messageGo to next message
faulksy wrote on Sun, 19 May 2002 1:35 AM
oh yeah shit!.. im using water as coolant for now.. only to get her started so i should use real green coolant
faulksy
Re: Idling.. Normal Or weird..? Sat, 18 May 2002 15:50 Go to previous messageGo to next message
shouldnt make a difference if its coolant or water. just check the level. when its low its get air bubbles passing throught the sensor which are at a lower temperature then the coolant causing the idle to rise. then the water passes which is at a iger temperature causing it to drop again.
SW20R
Re: Idling.. Normal Or weird..? Sat, 18 May 2002 15:58 Go to previous messageGo to next message
faulksy wrote on Sun, 19 May 2002 1:50 AM
yeah ill check it tommorow
and ill need to get me an 02 sensor..
IRA11Y
Club Member
Re: Idling.. Normal Or weird..? Sat, 18 May 2002 22:54 Go to previous messageGo to next message
The most likely cause of the surging is one of two things so in order
TPS is out of sinc and needs to be reset, If you have no idea what to do then take it to a mechanic because its not something to tackle unless you have a good idea about electronics and switching, it should take the mechanic about 15 mins to set it.
O2 sensor is not working correctly, check the diagnostics to see if theres a recurring fault
as for your minnimum idle once you get the surging fixed you can reset the idle by turning the screw thats on top of the throttle body ( sometimes covered with a little rubber bung about the size of a 5 cent piece) left is higher rpm right is lower rpm, make sure the engine is warm and idle has settled before adjusting
faulksy
Re: Idling.. Normal Or weird..? Sun, 19 May 2002 16:22 Go to previous message
I thought EFI idle was changed by rotating the dizzy capped? I'm not sure though.
Previous Topic:What you think of the new forum
Next Topic:Who Saw Star Wars?
Current Time: Sun Oct 18 01:15:13 UTC 2026
Total time taken to generate the page: 0.0057229995727539 seconds
