Toymods » Tech & Conversions » Well, I've found a half-cut at least...
joorsh
Well, I've found a half-cut at least... Tue, 04 November 2003 01:23 Go to next message
A nice big stinking auto 7M-GTE halfcut finally showed up, so I'll probably be going ahead with that one to chuck into the cressy. It's got a few kms on it (about 110,000), and it's missing the intercooler. Aside from that it seems pretty good. Is there anything in particular I should look out for, aside from shaft play in the turbo and a compression test on the cylinders? It can't be started due to the missing intercooler, but I'm thinking of plumbing a piece of pipe across the front to see if I can. The wreckers are usually pretty unhelpful when it comes to this sort of thing though.
I managed to talk them down to $1200. That's a pretty good price right? I hope I'm not being ripped off Neutral
-J-
Danners
Central Coast, NSW
Re: Well, I've found a half-cut at least... Tue, 04 November 2003 01:26 Go to previous messageGo to next message
Good price!
the biggest problem with 7M's is the head gasket. From a first glance you can't really tell if its been replaced or torqued down but when you buy the engine make sure you either replace the gasket with a metal one or torque the factory head bolts down to prevent it blowing
Dan
joorsh
Re: Well, I've found a half-cut at least... Tue, 04 November 2003 01:27 Go to previous messageGo to next message
Cheers!
Is there anything else I should look out for? Water pump problems? Common oil leak spots? I'm afraid I really don't know all that much about the 7M.
-J-
Re: Well, I've found a half-cut at least... Tue, 04 November 2003 01:50 Go to previous messageGo to next message
Do a compression test, do a leakdown test if you can, and look for all the common signs of a BHG (oil in water, water in oil, etc). Definitely start the bastard if they'll let you. If they won't let you, proceed with caution!
lumpy
Adelaide, SA
Re: Well, I've found a half-cut at least... Tue, 04 November 2003 01:51 Go to previous messageGo to next message
Check the front pulley - it is a common problem that these will come lose and wear the crank. Any play in it (when the belts are loose) is a bad sign. If there is play when the belts are tight, it's a REALLY bad sign!
knackers
berala sydney
Re: Well, I've found a half-cut at least... Tue, 04 November 2003 02:46 Go to previous messageGo to next message
hi joorsh
Have you all ready brought the 7m front cut or you about to buy it.
Make shore you get warranty with it or go some were else to buy one if they don't offer any warranty.There are a lot of rip off out there.
Were you thinking of buying it from ???
cya knackers
joorsh
Re: Well, I've found a half-cut at least... Tue, 04 November 2003 04:50 Go to previous message
Yeah, they're offering a 3 month warrentee. Otherwise I wouldn't touch it! I haven't bought it yet though.
-J-
Previous Topic:2TG mods??
Next Topic:Speedo problems cable >electric
Current Time: Mon Oct 26 13:29:33 UTC 2026
Total time taken to generate the page: 0.0093710422515869 seconds
