Toymods » Tech & Conversions » Circuit opening relay - question just to verify
Circuit opening relay - question just to verify Tue, 04 November 2003 12:35 Go to next message
Just to make sure i haven't got this TOTALLY wrong....
I am wiring up a 4age smallport from scratch (ie i had one fucked up loom to deal with). I have sorted just aboot everything, and have got to the 12 pin plug (body plug).
Already i have sorted out W, BATT, B1 and B+... but remaining is FC (circuit opening relay). From the diagrams i have (in japanese) it looks like its a negative output from the ECU to trigger a relay to give power to the fuel pump.
Am i correct in thinking that? Or just way off?
Thanks for any help.
Cressida Supra
Re: Circuit opening relay - question just to verify Tue, 04 November 2003 14:20 Go to previous messageGo to next message
from what i know, fuel pumps are wired up two ways
either one side is earthed, and the other floats betwween 0 and 12v (12v at WOT, 1v at idle)
or
one side is constant, and the other floats between 12 and 0 (0v being WOT, 11v at idle)
having said that, i dont see why you cant wire up a pump backwards and give it -12v constant, and -12 to 0 trigger (0v being WOT)
but hey, that could just be speculation
Cressida Supra
Re: Circuit opening relay - question just to verify Tue, 04 November 2003 15:04 Go to previous messageGo to next message
actually scrap that last bit
you cant get -12v from a car battery
it has to be one of the first 2 possibilities
have a good look at the diagram again
clubagreenie
1st street on the right
Re: Circuit opening relay - question just to verify Tue, 04 November 2003 18:49 Go to previous messageGo to next message
I don't know if it's the same but my crown (5mge) the fuel pump circuit opening relay is switched by two circuits. It is switched with ignition and also switched by the air flow meter (don't know if you have) when the flap is moved. This is a constant voltage, just on/off. It's done as a safety thing if the car stalls (accident) the pump also stops. One of the wires from the AFM will complete a circuit to earth (AFM body, make sure it's not a bad earth Laughing ).
The FC should be ign controlled and have full power at all times through startup to switch the 1st stage of the relay. As you crank the engine the AFM opens and switched the second stage and pump runs. I fed this to another std relay at the pumps. (cuct open is not the pump relay as such)
Justin
ddeane
PNG
Re: Circuit opening relay - question just to verify Tue, 04 November 2003 21:46 Go to previous messageGo to next message
Gidday
Justin is correct. Have a look at the iggte wiring diagram in the Gallery. It will show the wiring of the circuit opening relay. It is the same for all toyotas with AFM. Basically it there to ensure that if the engine is not running neither is the fuel pump - so if you have a prang the fuel pump is not continuing to pump fuel. All efi cars have some similar form of protection - eg hondas use oil pressure.
Craig
Grant
Newcastle, NSW, Australia
Re: Circuit opening relay - question just to verify Tue, 04 November 2003 22:11 Go to previous messageGo to next message
original Question:
"From the diagrams i have (in japanese) it looks like its a negative output from the ECU to trigger a relay to give power to the fuel pump."
Yes, that is correct. The ECU will ground the FC wire and complete the circuit. This is applicable for MAP sensed engines only, not AFM.
Re: Circuit opening relay - question just to verify Wed, 05 November 2003 10:51 Go to previous messageGo to next message
Thanks a zillion Grant! I checked over the diagrams again today and asked "The Man" a couple of questions, and now i even understand how the actualy Circ openning RELAY itself works (ie priming the pump whilst starting).
Im just going to use a regular SPST relay for now (have heaps spare), and if i have problems starting ill then use the proper Circ opening relay.
P.S. When i said
i would have thought most would know that it's MAP sensor... I don't care for AFM's.
clubagreenie
Re: Circuit opening relay - question just to verify Wed, 05 November 2003 11:33 Go to previous messageGo to next message
Just go to the wreckers and grab one (or two or three....)
I might have a spare if you want one
Re: Circuit opening relay - question just to verify Wed, 05 November 2003 12:45 Go to previous messageGo to next message
going to the wreckers = time required in the normal 9-5 realm... something which i do NOT have. Hence im using what i have handy at home.
If its a problem THEN i pinch one!
BansheeBuzz
Gold Coast
Re: Circuit opening relay - question just to verify Wed, 05 November 2003 20:39 Go to previous messageGo to next message
you should also have a wire from your start curcuit to trigure the relay on crank
Re: Circuit opening relay - question just to verify Thu, 06 November 2003 10:40 Go to previous message
thats only to prime the pumps whilst starting - i've worked around it now and have the relay coil and switch feed from permanent 12V, and the other side of the coil to the FC output of the ECU.
It'll work. Mostly.
Previous Topic:What colour for intercooler?
Next Topic:Anti-lag setup??
Current Time: Thu Nov 19 19:25:50 UTC 2026
Total time taken to generate the page: 0.0071020126342773 seconds
