Toymods » Tech & Conversions » 7m-gte in 83 st141 corona???
jackel
7m-gte in 83 st141 corona??? Tue, 04 November 2003 13:31 Go to next message
has anyone stuck a 7m-gte in a corona before, i've heard it can be done but it could be somewhat heavy n lots of things need upgrading?
my friends got a halfcut with a 7m-gte he said $1500 i'm thinking instead of a 1g-gte.
anyone got any suggestion or comments?
rob_RA40
c'town, NSW
Re: 7m-gte in 83 st141 corona??? Tue, 04 November 2003 21:07 Go to previous messageGo to next message
go the 1G
7M can be done but its much more trouble than a 1G
1ndecent
Re: 7m-gte in 83 st141 corona??? Wed, 05 November 2003 08:45 Go to previous messageGo to next message
Go the 7m, you'll enjoy skating past 1G equipped cars with the wheels spinning Very Happy
coronamark2
Re: 7m-gte in 83 st141 corona??? Wed, 05 November 2003 08:53 Go to previous messageGo to next message
You wouldnt be able to register it would you? i thought if your car was a 4cyl (which all the coronas after the mk2 are) that you cant put a 6cyl in and register it?
im not 100% sure but id find out before doing anything, im planning on the 7mgte i have a 6cyl 4m in my car now so it will bolt up to the same engine mounts with a bit of sump modification.
good luck either way
[Updated on: Wed, 05 November 2003 08:54]
wilbo666
Re: 7m-gte in 83 st141 corona??? Wed, 05 November 2003 09:44 Go to previous messageGo to next message
coronamark2 wrote on Wed, 05 November 2003 19:53
You prbly much more in the know that me Cool , but I thought that for the sump you would be fine if you use your 4M one?
(just I've read about a 5M-E -> 7M-GTE in MA61's and I think thats what he did?)
7M-Brisbane
Re: 7m-gte in 83 st141 corona??? Wed, 05 November 2003 11:49 Go to previous messageGo to next message
Having put a 1GGTE into an ST141, I can say with some certainty that a 7MGTE would be no problems. Ideally you'd run a W58 5-speed, that way you can run a tailshaft off an RT142 and the box will bolt to the floor and the shifter will line up perfectly.
You also end up with the engine in basically the ideal spot - may be a little massaging due as the 7M has a coolant hose coming out of the back of the cylinder head on a ~60 degree angle. Aside from that and the radiator relocation I see very few issues apart from legal ones.
To my knowledge there is no state in Australia which would allow you to register such a machine.
A 13BT, SR20DET, 1UZFE or 1JZGTE might be a better option - although on the 1JZ and 1UZ you are likely to need expensive custom manifolds made up.
jackel
Re: 7m-gte in 83 st141 corona??? Wed, 05 November 2003 13:00 Go to previous messageGo to next message
well if i can't get a 7m corona registered then i might have to go for the 1g Sad
otherwise could take it down the tracks and screw around with it Razz
not bad for $1500 tho...
jackel
Re: 7m-gte in 83 st141 corona??? Thu, 06 November 2003 15:23 Go to previous messageGo to next message
everyone says 13b, sr20 better then the 1g?
which would be cheaper, less hassle, more powerful and worth it's dollar?
Layoric
Canberra ACT
Re: 7m-gte in 83 st141 corona??? Thu, 06 November 2003 15:32 Go to previous messageGo to next message
Why can't you get it registered? I know a guy with a 351 mark 2 Escort registered and a 351 Mark 2 Capri. They have engineering certs though, you might have to get that done, but i thought you did with nearly all engine conversions?
Layoric
Re: 7m-gte in 83 st141 corona??? Thu, 06 November 2003 22:54 Go to previous messageGo to next message
Sounds like the engine conversion rules in the NT are a lot more relaxed in the Eastern states! There's no way a 351 in an Escort would be allowed here...
rob_RA40
c'town, NSW
Re: 7m-gte in 83 st141 corona??? Thu, 06 November 2003 23:43 Go to previous message
it could have been engineered a long time ago before the current capacity laws where brought into place.
now a 7M-GTE in a anything after a RT132 is legal, but installing a 7M will be MUCH more hassle to get it to fit in the bay.
Previous Topic:5ME ECU
Next Topic:Crankless
Current Time: Tue Nov 24 21:03:33 UTC 2026
Total time taken to generate the page: 0.015295028686523 seconds
