Toymods » Tech & Conversions » 2t/3t geu cams
Pheonix
Wa
2t/3t geu cams Wed, 05 November 2003 13:20 Go to next message
hey guys, ive begun the 2t/3t hybrid project, looks all good atm. I have a question though, im planning on putting 304/304 cams in the engine, i was wondering if it was possible to regrind the standard cams from the 2t geu to 304 or would i have to buy new cams??
Pheonix
Wa
icon5.gif  Re: 2t/3t geu cams Fri, 07 November 2003 12:53 Go to previous messageGo to next message
bump
SeptemberSquallIndustries
Re: 2t/3t geu cams Sat, 08 November 2003 12:30 Go to previous messageGo to next message
My less-than-helpful suggestion would be to consult a cam shop.
Jonny2TG
Tasmania
Re: 2t/3t geu cams Sun, 09 November 2003 06:41 Go to previous messageGo to next message
Standard 2T-G cams can be regroud for 304 degrees, or whatever you want. To do this they reduce the base circle meaning you need to use thicker ships, which i ok I think. If you can spend some money, get the shop to first weld the cams before grinding them so they can maintian the base circle.
I think Wadde camshafts in Melbourne is where mine came from.
EMP-2TG
Carlingford, Sydney
Re: 2t/3t geu cams Mon, 10 November 2003 03:18 Go to previous messageGo to next message
hows your new motor coming together jonny?
EMP-2TG
Carlingford, Sydney
Re: 2t/3t geu cams Mon, 10 November 2003 03:19 Go to previous messageGo to next message
Jonny2TG
Tasmania
Re: 2t/3t geu cams Mon, 10 November 2003 08:35 Go to previous messageGo to next message
Its still in bits. I lightened the flywheel down to about 6.5kg. Drilled some holes etc. The flywheel and 3T crank are now getting machined and ballanced. Maybe I will make a alloy pully so that can get ballanced with it also.
3T-C pistons are getting the valve releifs machined not also, but these machine shops are taking there time. Also a conrod had to get resized for some reason.
Got a 2T-GEU gasket kit on e-bay!!! Cheaper.
Head is cracked through the spark plug holes Sad I may need to find another head to start with or get this repared. Would prefer a 88222 head or maybe 88260.
Will buy new double valve springs, chains, chain dampers etc from swmotorsport.com.au soon.
I have wadde 305.5 degree cams going in. One of then is a regrind only and need thicker shims.
Block is at 86mm with 3T crank/pistons. 1813cc
EMP-2TG
Carlingford, Sydney
Re: 2t/3t geu cams Mon, 10 November 2003 08:55 Go to previous message
awesome
sounds like it will be a heap of fun Smile
i should get off my arse and do somthing with mine Rolling Eyes
Previous Topic:1JZ non turbo engine
Next Topic:anyone with a 4AGZE help
Current Time: Fri Oct 23 19:09:36 UTC 2026
Total time taken to generate the page: 0.0055789947509766 seconds
