Classifieds » Miscellaneous » sold: BRAND NEW APEXi S-AFC II LATEST MODEL
SilyKa
sold: BRAND NEW APEXi S-AFC II LATEST MODEL Wed, 05 November 2003 22:59
I GOT A BRAND NEW SAFC II < With Apexi Stand > ( IN BOX NEVER USED ) SAFC II The second-generation S-AFC is a fuel computer that adjusts fuel/air ratio by modifying the air-flow meter/MAP sensor signal. The S-AFC features a user-definable, eight-point, adjustable fuel curve that can be set in 200 RPM increments. The range of fuel adjustment is 12 points +/- 50% at each of the user-defined setting points. On hot-wire vehicles, the Deceleration Air Flow Correction function is capable of curing the erratic idle and stall problems associated with open-atmosphere blow-off valves on hot-wire air-flow meter systems. The S-AFC is capable of monitoring and replaying the following data channels in Numerical, Analog Meter and Graph displays: Intake Manifold Vacuum/Boost Pressure, Air Flow Capacity, Intake Manifold Pressure, Kaman Frequency, Engine RPM, Throttle Position, and Air Flow Correction %. Modifies air-flow meter signal (pressure signal in some vehicles) to optimize fuel-air ratio; Vacuum Fluorescent Display (VFD).
asking $550.
for further details check the apexi websites, even usa site is not on offer yet.
cheers,
[Updated on: Sun, 09 November 2003 21:54]
Previous Topic:FS: MA70 lowering springs
Next Topic:Hilux 4 pot calipers & 302mm rotors
Current Time: Tue Oct 20 22:53:49 UTC 2026
Total time taken to generate the page: 0.0079278945922852 seconds
