Toymods » Tech & Conversions » 1JZ Flywheel Bolt Torque
Skip
icon2.gif  1JZ Flywheel Bolt Torque Wed, 05 November 2003 23:30 Go to next message
As the title suggests, im chasing 1JZ flywheel bolt torque setting.
wastegate
Gold Coast
Re: 1JZ Flywheel Bolt Torque Thu, 06 November 2003 05:59 Go to previous messageGo to next message
Install 2 new bolts
First, torque the 2 bolts uniformly a little at a time
Torque: 49 N-m (500 kgf-cm, 36ft-lbf)
Then tighten the 2 bolts an additional 80-100º.
BlackSupra
Re: 1JZ Flywheel Bolt Torque Thu, 06 November 2003 06:04 Go to previous messageGo to next message
and dont break them
they are $$$$$$$$
Skip
Re: 1JZ Flywheel Bolt Torque Thu, 06 November 2003 07:55 Go to previous messageGo to next message
So:
1. put 2 bolts in 180 degrees apart from each other
2. tighten uniformly
3. torque them to 49 Nm
4. tighten an addtional 80-100 dgrees past 49 Nm
5. install rest of bolts and torque to 49 Nm
Should you also put a little Loctite on?
wastegate
Gold Coast
Re: 1JZ Flywheel Bolt Torque Fri, 07 November 2003 00:04 Go to previous message
Put them all in and tighten them uniformily in the pairs. You tighten them all to 49Nm + 90degrees.
Yeah loctite if you want.
Previous Topic:18R conversion advice pls.
Next Topic:5ME ECU
Current Time: Thu Nov 19 15:39:24 UTC 2026
Total time taken to generate the page: 0.0057690143585205 seconds
