Toymods » Tech & Conversions » My car is wacked
ta23
My car is wacked Thu, 06 November 2003 12:00 Go to next message
Was driving to get petrol today and the car started fine and drove to the petrol station fine, put fuel in it, went back out to start it and it kicked but just just died, after numerouse attempts the car wouldnt start so I pushed it to a park and left it there.
I came back about 4 times during the day to double check everything, make sure it wouldnt start and still got the same result. After deciding I would have to tow it home I got tow rope and headed back there at like 8pm, thought I would try kick it and it started, felt fine, drove fine and I was able to drive it around all night.
When trying to start at the petrol station it would kick, idle really low and conk out, when I was able to get the revs up they would drop as if the car was really cold and had no cold start. Also heard a couple of popping sounds, but have heard them before with no worries
Any suggestions Confused
clancey
Re: My car is wacked Thu, 06 November 2003 12:05 Go to previous messageGo to next message
Fuel or ignition, check everything Smile I'd check your fuel pumps and timing first and work back from there.
coronamark2
Re: My car is wacked Thu, 06 November 2003 13:35 Go to previous messageGo to next message
check your alternator and battery + coil/ballast resistor these are all things that need to be working to start your car i found out the hardway:
came home went to move the car wouldnt start so i went and got a new battery started up sweet, next day driving to work car conks out towed it home got a new alternator but it in sweet week after that go to a mates cars driving sweet go to leave wouldnt start fkd ballast resistor got a coil as well just to make sure )dont worry i got a new starter motor before all of this) Laughing
STR8 2.8
Re: My car is wacked Thu, 06 November 2003 23:23 Go to previous messageGo to next message
make sure u didnt put diesel in it? Laughing
ta23
Re: My car is wacked Fri, 07 November 2003 01:13 Go to previous messageGo to next message
The car started fine, just wouldnt go fine until I left it there all day and came back later that night to tow it home, then it started fine and went fine. weird Confused
T APLUS 22
Re: My car is wacked Fri, 07 November 2003 15:41 Go to previous messageGo to next message
hey man, I had a similar problem with mine. was it cold? ie: could it be the choke is stuffed? Also I'd be cheking the points and ignition setup, could be really dirty. hope this helps. oh and I'm guessing this is why u needed sean moloney's ph number.
FKN16V
NSW, East Coast
Re: My car is wacked Fri, 07 November 2003 23:09 Go to previous messageGo to next message
Is this the first time its happened.
There wasnt any water/moisture in the fuel line was there.
ta23
Re: My car is wacked Sat, 08 November 2003 13:24 Go to previous messageGo to next message
T APLUS 22 wrote on Sat, 08 November 2003 02:41
It fuel injected so there is no choke, and no it wasnt cold and I had just driven it to the petrol station anyways, yea need sean's no. to put some new distributor leads. Thanks anyway
ta23
Re: My car is wacked Sat, 08 November 2003 13:26 Go to previous message
FKN16V wrote on Sat, 08 November 2003 10:09
Yep first time it has happened, how do I check if there is moisture in the fuel line.
My theory is perhaps because it needs new distibutor leads maybe it wasnt sparking properly and flooding the engine, but I still dont get why it started up later on in the day.
Previous Topic:quick help
Next Topic:Fitting a MICROTECH system to a 3T GTE???
Current Time: Sun Oct 18 20:02:34 UTC 2026
Total time taken to generate the page: 0.033113956451416 seconds
