Toymods » Tech & Conversions » is borg warner KE30 diff stronger than the non BW one?
_555_
SOR, Perth
is borg warner KE30 diff stronger than the non BW one? Thu, 06 November 2003 13:00 Go to next message
just like above, I have a KE30 corolla with a regular
(non-BW) diff and am thinking of fitting a BorgWarner diff?
Is it worth it?
[Updated on: Thu, 06 November 2003 13:03]
CLG
Perth, Western Australia
Re: is borg warner KE30 diff stronger than the non BW one? Thu, 06 November 2003 13:06 Go to previous messageGo to next message
Yep, they are a good stop gap measure until you can afford something decent, I installed one for a 3TGTE conversion into a KE30, and didn't have a problem with it, but also told the owner to be nice to it!
_555_
SOR, Perth
Re: is borg warner KE30 diff stronger than the non BW one? Thu, 06 November 2003 13:25 Go to previous messageGo to next message
Thanks for the info!
[Updated on: Thu, 06 November 2003 13:34]
Re: is borg warner KE30 diff stronger than the non BW one? Thu, 06 November 2003 13:46 Go to previous messageGo to next message
as Clint said, it's all about how nice you are.
i personally think that they are about the same strength, and both will die when you treat them badly...
i have heard of ppl with 4AG's with both types of diff with no problems, but then again, i know of a few ppl who have bog stock 3K's and they continually break diffs and axles... all depends on how you use it..
personally, i wou;d not bother changing. the Jap centres are very easy to change compared to the whole BW axle, and it all comes down to your usage.
Clint, so you think the BW is actually much better than the jap diff??
Cya, Stewart.
CLG
Re: is borg warner KE30 diff stronger than the non BW one? Thu, 06 November 2003 14:18 Go to previous messageGo to next message
Structurally, I think they are moderately stronger, but not overly so (everone be aware this is my observation and theory, but not proven). Both are easy to break if not treated nicely!
faulksy
Re: is borg warner KE30 diff stronger than the non BW one? Fri, 07 November 2003 01:53 Go to previous messageGo to next message
having had both behind a ke30. BW wins hands down everytime. they tend to make more whining noises when on the way out while the banjo's seem to give no warning. bigger drums are an advantage aswell. they seem to be more common. banjos were only available on the imported japenese ke30s i believe. with early diffs like ke30/55 its just as easy to change the whole diff (drum to drum) then change the centre. we just mean you will have to bleed the brakes. my last diff lasted over 8 months on my ke30 before breaking. treat it with respect and it should last
Jason
Re: is borg warner KE30 diff stronger than the non BW one? Fri, 07 November 2003 02:09 Go to previous messageGo to next message
Before i learnt to settle down a bit i did 2 banjo's and a BW diff in my KE30 with 3k. Not to mention how many gearbox's i went through.
_555_
SOR, Perth
Re: is borg warner KE30 diff stronger than the non BW one? Fri, 07 November 2003 03:30 Go to previous messageGo to next message
Thanks guys I will keep that in mind when using
the BW diff!
Re: is borg warner KE30 diff stronger than the non BW one? Fri, 07 November 2003 07:00 Go to previous messageGo to next message
interesting Smile
the banjos are pretty common on KE10's and 20's and all the KE30's i have seen had banjos (55's had more BW due to more aussie content) although KE10's had BW's as well!!
i've only had 2 diff failures.. 1 was an a very long very high speed corner, and one of the pinion bearings exploded (literally). the other was two teeth coming off the pinion gear, fron fatigue... these are both KE10 banjo diffs...
gearboxes... ewww, they always break if you treat them badly (ie flatchanging)
anyone got some spare K40 internals in sydney??
Re: is borg warner KE30 diff stronger than the non BW one? Fri, 07 November 2003 07:39 Go to previous message
I've got k40 guts kicking around Evil or Very Mad
I'm on my fourth diff in my ke55, I've used both the banjo and the bogwarmer variety, and they're both weak as piss Very Happy That said, either will last fine if you're GENTLE!
Previous Topic:UK newbie with 4a-gze corolla
Next Topic:Differences in #A22 and #A23 Celicas
Current Time: Fri Nov 20 00:42:46 UTC 2026
Total time taken to generate the page: 0.0052580833435059 seconds
