Toymods » Tech & Conversions » 4agze boost problems
cmwb
Devonport, Tasmainia!
icon8.gif  4agze boost problems Fri, 07 November 2003 00:56 Go to next message
hi just put a gze in my ae86 and it is not coming up on toboost strait away it will go up to 4psi then slowlly go around to 8psi then creap up to 10psi just before it hits the rpm limiter! any help wold be great! and the are serposed to run 3 vac switches mine only has the one that cotroles the s/c what are the other 2 for the harness still has the plugs for the other 2
cmwb
Re: 4agze boost problems Fri, 07 November 2003 02:26 Go to previous messageGo to next message
*bump*
Esteban
Brisbane - Chapel Hill
Re: 4agze boost problems Fri, 07 November 2003 02:29 Go to previous messageGo to next message
is your belt slipping? it's usually pretty noisy if it is
tighten/clean the belt, try some CRC belt non-slip stuff, and/or grab a newer one.
failing that, it could be a number of other things not quite so simply fixed.
cmwb
Re: 4agze boost problems Sun, 09 November 2003 01:25 Go to previous messageGo to next message
no i think the belt is fine unless they have to be super tight! but cant hear it at all!! thanks any way!
GZE-STYLE
Camden
Re: 4agze boost problems Sun, 09 November 2003 07:07 Go to previous message
The s/c belt has to be pretty tight. Have you done the ABV mod? Any air leaks? What intercooler you running?
Previous Topic:CSX Vs CS Vs SX secas
Next Topic:download solex tuning manual
Current Time: Thu Nov 26 10:06:18 UTC 2026
Total time taken to generate the page: 0.0058472156524658 seconds
