Classifieds » Parts Wanted » MA61 analogue dash wiring harness
82MKII
MA61 analogue dash wiring harness Fri, 07 November 2003 09:58 Go to next message
I need a wiring harness (just the bit that plugs into the back of the instrument cluster) out of a Euro spec MA61 (the ones with analogue dash). I'm guessing the harness out of a RA60/65 would also do the job.
Peter
BlackSupra
Re: MA61 analogue dash wiring harness Fri, 07 November 2003 13:06 Go to previous messageGo to next message
The reason the plug was used was to unplug the motor.
Remove the existing dash plug (on the 1J) and swap it for the one in your car, unless you intend to replace the engine and ecu back into your car someday.
alternatively you can just wire the wires straight up, but the plug is such a good idea.
82MKII
Re: MA61 analogue dash wiring harness Fri, 07 November 2003 13:26 Go to previous messageGo to next message
Yeah - I believe the plug should plug straight into my harness. The reason for the spare harness is to hook up my spare instrument cluster for the test start out of the vehicle.
Just seeing if I can get one.
BlackSupra
Re: MA61 analogue dash wiring harness Sat, 08 November 2003 05:43 Go to previous message
Remove the cluster from the car
You are going to have to anyway to wire up the gauges Wink
Previous Topic:WTB:AE86 driver side interior door panel
Next Topic:hub cap's
Current Time: Sat Nov 21 08:21:36 UTC 2026
Total time taken to generate the page: 0.0052061080932617 seconds
