Toymods » Tech & Conversions » Crank angle sensors and microtech help please
ChuckLandwehr
Crank angle sensors and microtech help please Wed, 24 July 2002 11:01 Go to next message
Hey guys, I am an old school guy points/dwell etc. I desperately need some expert electrical advice.
Putting a new computer MT in a TA22 with 3TGEU.
Can an old dizzy with a hall effect sensor act as a crank angle sensor?
Hall effect sensor, has wire in wire out. = 2 wires
Crank angle sensors appear to have a signal generator, and a hall effect sensor. = 4 wires.
If I hook this up incorrectly, I risk damage.
Tis a tad too late in the evening to call microtech, any help would be greatly appreciated,
regards, Chuck.
Pete
gold coast
Re: Crank angle sensors and microtech help please Wed, 24 July 2002 11:13 Go to previous messageGo to next message
Hey mate, to run sequential fuel injection you will need a 4 sync pulses and one reference pulse.(At No 1 TDC)
Your sort of dizzy will not provide this sort of signal. It will run batched injection.
You may be able to buy an induction pickup for no 1 spark plug to give you the reference pulse.
(Get a second opinion, I am no expert)
ddeane
PNG
Re: Crank angle sensors and microtech help please Thu, 25 July 2002 10:20 Go to previous messageGo to next message
Charles
Microtech should be your first point of reference. Give them a ring and put the problem to them. If that does not help we should get together and have a read of the manual.
Craig
ChuckLandwehr
Re: Crank angle sensors and microtech help please Thu, 25 July 2002 11:00 Go to previous messageGo to next message
Thanks guys, Microtech have configured the computer for a CAS, and advised us to use any late model Toyota CAS , fantastic in theory, however most "late" model Toyota's use an OHC driven distributor or CAS, not an old side cam design as in the 2TGEU.
HUGE problems in trying to adapt a CAS to fit into a tiny 2TG dizzy housing.
To the Electrical: A true CAS requires;
a. Crank angle reference signal generated by a multicog toothed wheel passing a hall effect sensor, and
b. TDC or home signal, again utilizing a hall effect sensor.
If I send the computer back to Microtech to be configured to use the single hall effect sensor, I will lose sequential firing of injectors, and the ability to drive coil packs.
Has anyone got any suggestions on another engine type which could be canabalized to get a CAS
GIN51E
Berowra-Sydney
Re: Crank angle sensors and microtech help please Thu, 25 July 2002 11:26 Go to previous messageGo to next message
just a question, what is a crank angle sensor? my friends commadore had a problem where it would just stop whenever it wanted to and they found the problem to be a crank angle sensor so i was interested to know what this actually does? whats it there for?
Asking questions is the only way to learn. Nod
Esteban
Brisbane - Chapel Hill
Re: Crank angle sensors and microtech help please Sat, 27 July 2002 00:49 Go to previous messageGo to next message
Crank angle sensor simply tells the ECU what position the crank is at. From this information, the ECU can derive RPM, when to open/close injectors, spark timing etc ...
So without it (on a system that requires it) you are pretty much fscked
GIN51E
Berowra-Sydney
Re: Crank angle sensors and microtech help please Sat, 27 July 2002 09:34 Go to previous messageGo to next message
ahh ok cool so that explains why the engine would turn itself off at times. Nod
ChuckLandwehr
Re: Crank angle sensors and microtech help please Sat, 27 July 2002 09:36 Go to previous messageGo to next message
Thanks for the input guys. Does anyone in SYDNEY know of a business up ther that custom makes distributors?
regards Chuck.
SUPRAGTE
North Sydney
Re: Crank angle sensors and microtech help please Tue, 30 July 2002 09:08 Go to previous message
I know with some other ecu's you can setup an equivalent crank angle sensor with magnets or chopper disk on the main crank pulley and a bracket with sensors on it.
Maybe microtech can.
Previous Topic:Bosch fuel pump for GTST skyline??
Next Topic:Reconditioning a Dash
Current Time: Thu Oct 29 07:14:29 UTC 2026
Total time taken to generate the page: 0.045200109481812 seconds
