Toymods » Tech & Conversions » 7m query
thug_immortal
Camden, NSW
7m query Sat, 08 November 2003 04:04 Go to next message
The head gasket on the 7mgte has been retourqued to try and prevent/eliminate the head gasket issue. Is this enough or should i just put a metal gasket in to be safe?
Allan
Re: 7m query Sat, 08 November 2003 05:30 Go to previous messageGo to next message
maybe! if it blows obviously not till then dont stress
Allan
thug_immortal
Camden, NSW
Re: 7m query Sat, 08 November 2003 06:17 Go to previous messageGo to next message
yeah stressing cos it could be lots of $$$$$ in damage :S
Re: 7m query Sat, 08 November 2003 08:37 Go to previous messageGo to next message
If it's totally stock, the factory gasket is usually good enough after you've re-torqued the head. Just make sure you never overheat it! As soon as you modify it though (and this includes running more boost), you're taking a gamble. Some people get away with it, others don't.
Personally I'd hate to drive my car around being constantly afraid of blowing the head gasket. This is most of the reason I got rid of my 7M before I even began my engine conversion!
dingaling
tas
Re: 7m query Sat, 08 November 2003 08:55 Go to previous messageGo to next message
when i buaght my supra in july, the previous owner just had the headgasket done, i just recently retorqeued the head to 68lb's half the bolts were alot less then even 52lbs, i hope it holds up for a good while or i'll have to spend lots of money machining and gettting a metal HG/ARP bolts done.
*fingers crossed*
TheStitt
Membership Secretary
Re: 7m query Sun, 09 November 2003 00:30 Go to previous messageGo to next message
Is there much of a problem with the GE and what should the bolts be torqued to???
V8_MA61
Re: 7m query Sun, 09 November 2003 00:33 Go to previous messageGo to next message
same problem matew tith 7mge as to 7mgte. Turbos were just more common due to their harsher operating conditions. O-ringing the head can be done to a slight advantage. Perhaps a thermofan to help prevent heatsoak as well?
Blake.
ViNcEnXo
Re: 7m query Sun, 09 November 2003 01:30 Go to previous messageGo to next message
The Soarer I have just bought had a blown headgasket 10,000k's ago and was replaced under a dealer warranty. They wouldn't have used a HKS metal headgasket... so what would they have used? A toyota revised one? And what would they have torque'd the head bolts to? Should I get them re-checked to be on the safe side? What should they be?
Paul
V8_MA61
Re: 7m query Sun, 09 November 2003 01:38 Go to previous messageGo to next message
should be torqued to 72ft/lbs from my memory. YEs definetly have them checked. Another bhg, is going to cost you 1k+ to have fixed. Theres a few you can use. Toyota ones are the best (unless mhg is warranted). Then theres a heap of brands, ranging down to the $30 a gasket suprcheap ones..which i strongly reccomend not using!
TD42T
Mildura
Re: 7m query Sun, 09 November 2003 10:48 Go to previous messageGo to next message
$30 7m head gasket where are you getting them?
In some cases no matter what you do nothing will prevent it going.
I have seen several where the gasket basically rots away and nothing is left of it.These I suspect where originals.
Marty
V8_MA61
Re: 7m query Sun, 09 November 2003 10:51 Go to previous message
$30 for a head gasket?! Come on, spending that much, you're asking for trouble!
Previous Topic:recoring an intercooler
Next Topic:HELP
Current Time: Fri Oct 16 15:33:25 UTC 2026
Total time taken to generate the page: 0.093003034591675 seconds
