Toymods » Tech & Conversions » will my box gear fit into an r154?
V8_MA61
will my box gear fit into an r154? Sat, 08 November 2003 13:20 Go to next message
Hi guys
Im contemplating going to an r154 in my ma61..from a w57 (slackass before me replaced the 58 with a 57 Mad) .
so i'm wanting to know, if all my crs ford to toyota supra box stuff will go into an r154? That means clutch, flywheel, fork, brace..everything? I know its been asked a thousand times, but what mods have to be done to the tailshaft again? Shifter location?
I know the bolt pattern is different, so id have to bog and re-drill my bellhousing.
Blake.
[Updated on: Sat, 08 November 2003 13:26]
CLG
Perth, Western Australia
Re: will my box gear fit into an r154? Sat, 08 November 2003 14:19 Go to previous messageGo to next message
Input shaft and spline are the same, so I don't see why not. I'd also suggest calling CRS and asking them if they'll swap the bellhousing over with a cash adjustment if needs be?!
V8_MA61
Re: will my box gear fit into an r154? Sat, 08 November 2003 14:22 Go to previous messageGo to next message
They wanted over $100 to do it from memory..its not hard to bog up holes in alloy is it? Easy to re-drill when theres a pattern to follow!
That the least of my worries though..so i should be right with ALL the ford clutch and manual stuff i have at the moment?
Blake
CLG
Re: will my box gear fit into an r154? Sat, 08 November 2003 14:32 Go to previous messageGo to next message
Only you will be able to find out by trying it. If you like I'll make a copy of my bellhousing on paper and send it to you, so you know where to drill the new points, get the other holes TIG'd up and smoothed then.
V8_MA61
Re: will my box gear fit into an r154? Sat, 08 November 2003 23:09 Go to previous messageGo to next message
That'd be great man Smile Ill pm you mt address later
Re: will my box gear fit into an r154? Sun, 09 November 2003 01:47 Go to previous messageGo to next message
Lemme know how it goes, I would be interested, as I may have to end up swapping my W box for an R154 sometime (after I break a couple!)
Greg55_99
Boston, USA
Re: will my box gear fit into an r154? Sun, 09 November 2003 15:34 Go to previous messageGo to next message
Try John Douglas's adapter plate:
http://members.iinet.net.au/~ozrunner/AdapterR150. html
Greg
Skip
Re: will my box gear fit into an r154? Sun, 09 November 2003 23:24 Go to previous message
I think John had a bellhousing made up by dellow.
Previous Topic:Some major rear end noise. Metalic grating sounds and whining and rubbing... not cool
Next Topic:stud change paten from 5 / 100 to 5 / 114.3
Current Time: Fri Oct 23 10:10:21 UTC 2026
Total time taken to generate the page: 0.0067319869995117 seconds
