Toymods » Tech & Conversions » 4AGE AE 92 SX
barbel
4AGE AE 92 SX Wed, 24 July 2002 12:12 Go to next message
My SX has runs quite harsh 3500-5000rpm, it's like something out of balance but it goes away as you climb furhter into the rev range. I don't notice it when the engine is free reved. The car has done 260k but seems to still go strong. Could this be caused by low fuel pressure?
spr000
Re: 4AGE AE 92 SX Wed, 24 July 2002 15:18 Go to previous messageGo to next message
timing problems?
barbel
Re: 4AGE AE 92 SX Thu, 25 July 2002 04:20 Go to previous messageGo to next message
have checked timing. seems ok.
spr000
Re: 4AGE AE 92 SX Thu, 25 July 2002 14:41 Go to previous messageGo to next message
usually a timing related problem (no power before certain rpm, but no problem with free revving)..
u have correct octane fuel? check knock sensor? any error code from ecu? check ignition system from distributor shaft, distributor cap, rotor, spark plug wire & spark plug? Your description really sounded like timing being too "retarded"
barbel
Re: 4AGE AE 92 SX Thu, 25 July 2002 23:41 Go to previous messageGo to next message
could it be a fuel problem, timing retarding because not enough fuel? we've got a feeling the pump might be on the way out? will have to get it tested,
or does it sound more like a dizzy, computer problem??
is it a common problem for the pumps to stuff up?
[Updated on: Thu, 25 July 2002 23:42]
spr000
Re: 4AGE AE 92 SX Fri, 26 July 2002 03:10 Go to previous messageGo to next message
cannot imagine it being "not enough fuel" because higher revs naturally needs more fuel, so could be the dizzy (or part of the ignition system) faulty ECU could cause all types of problems, but they're usually fairly reliable, so I'd check the ignition system first..
raSkaS
Perth WA
Re: 4AGE AE 92 SX Fri, 26 July 2002 09:30 Go to previous messageGo to next message
fuel pumps do have a tendency to fail if the car constantly has less than 1/4 tank of gas, this is because the pump relys on fuel to keep it cool
Cam
barbel
Re: 4AGE AE 92 SX Sun, 28 July 2002 10:10 Go to previous messageGo to next message
There is an error message from the ECU but it indicates the o2 sensor circuit failure.
I was unaware that this model has a knock sensor, where is it located?
spr000
Re: 4AGE AE 92 SX Sun, 28 July 2002 15:42 Go to previous message
since you're getting an error with the oxygen sensor, I suggest you should check it first, take the sensor out and see if it's worn (is the top part of the sensor worn with holes or crack etc.) if not, clean the sensor with steel wool, clear the ECU memory and drive a few hours and see what other errors is left in the ECU..
Previous Topic:jets in carburetors (solex)
Next Topic:GX60 Spare Parts
Current Time: Wed Nov 18 14:53:14 UTC 2026
Total time taken to generate the page: 0.0056178569793701 seconds
