Toymods » Tech & Conversions » IJZ MKII Conversion
backpeddler
IJZ MKII Conversion Sat, 08 November 2003 23:39 Go to next message
Hello
I'm trying to decide on a chassis for my 1JZ (MKIII) front cut. Obviously the easiest is to find a MKIII, but i've always considered the MKII a tough looker, and reckon the extra 100k or so lighter weight may make things a little more animated.
So can anyone give me a heads up on what's required for a 1JZ with manual gbox into MA61? I'm mainly interested in mechanicals here... ie engine / gbox mounts, alignments, clearances re sump and steering cross member, turbos and master etc etc.
Any comments on wiring the factory JZA70 ECU/loom into MA61 would also be greatly appreciated.
Tim
Rolling Eyes Shocked
Re: IJZ MKII Conversion Sun, 09 November 2003 00:06 Go to previous messageGo to next message
It's all pretty straightforward if you have a front mounted sump, which unfortunately you do not. You'll need custom engine mounts of course, but there are no clearance issues to be concerned about. Gearbox is easy if you use a 2JZ-GE W58 (bolts straight up), but with a bit of extra work you can squeeze in an R154.
Oh yeah, a Mk2 is actually 200+ kg lighter than a Mk3, so you'll be doing 12's without raising a sweat. Smile
Re: IJZ MKII Conversion Sun, 09 November 2003 06:49 Go to previous messageGo to next message
yep, you'll need a new sump. places will sometimes swap a front sump for a mid/rear sump, plus a little extra money - so do that if you can.
engine mounts can be had thru JAZE on these forums for $250. the 2jz-ge w58 will be required, as norbie mentioned. Wiring is pretty easy - I'm in the process of doing that at the moment - there's not a whole lot that needs to be cut/soldered.
some of the lines need to be re-routed/lengthened, and if you have an auto car you need to cut the shifter hole a little bigger (next on my list)
otherwise pretty damn easy - I just moved the gbox and engine from my wreck and into the new car in less than 3 hours, so it doesn't take a huge amount of time either (of course, all the peripherals and wiring still have to be sorted out)
BlackSupra
Re: IJZ MKII Conversion Sun, 09 November 2003 07:19 Go to previous messageGo to next message
The bellhousing is an uber prick to get ahold of!!!!!!!!
Dont forget custom power steering lines!
Re: IJZ MKII Conversion Sun, 09 November 2003 07:41 Go to previous messageGo to next message
Power steering is for pussies.
Re: IJZ MKII Conversion Sun, 09 November 2003 09:24 Go to previous messageGo to next message
and people with 245 rubber up front
backpeddler
Re: IJZ MKII Conversion Mon, 10 November 2003 08:36 Go to previous messageGo to next message
Thanks guys
I prefer to use the 1J 5spd... the R154 is the MA70 box (???), i take it the same box resides behind the 1JZ?
The idea is bang for bucks... clean n lean but no show pony
Guess i'll start looking for a good MKII; might as well be a pussy too... and keep the ps. Will try to rid the hydraulic fan setup.
Appreciate the advice
Smile
BlackSupra
Re: IJZ MKII Conversion Mon, 10 November 2003 08:48 Go to previous messageGo to next message
R154 is the box behind the 1J
It will need slight encouragement to fit, but has been done.
www.celicasupra.com
Re: IJZ MKII Conversion Mon, 10 November 2003 08:56 Go to previous messageGo to next message
getting rid of the hydraulics is pretty easy - just need a soarer water pump and some thermos (I'm in the middle of that now)
Thruan
mackay
Re: IJZ MKII Conversion Wed, 08 September 2004 04:12 Go to previous messageGo to next message
RIGHTO. i should be getting a ma61 pretty soon and will be doing the 1jz conversion. how much did it cost those that have done it? how long has it taken and is there any conversion 'diaries' that you kno of?and you said that engine mounts can be gotten of JAZE, is that the custom ones that will bolt straight into the bay and onto the engine???
Re: IJZ MKII Conversion Wed, 08 September 2004 06:30 Go to previous messageGo to next message
Wow this is an old thread!
The only conversion "diary" I know of is my site; it covers my 2JZ conversion but a 1JZ conversion is similar.
http://www.norbie.net/Project2JZ/
7M-Brisbane
Re: IJZ MKII Conversion Wed, 08 September 2004 07:24 Go to previous messageGo to next message
Oooh nasty.. cut down by your own insult 12 months later. So the fact that your Supra has power steering would make you what now? Very Happy
Re: IJZ MKII Conversion Wed, 08 September 2004 07:28 Go to previous messageGo to next message
Ghey. With aids.
Danish
Re: IJZ MKII Conversion Wed, 08 September 2004 08:00 Go to previous messageGo to next message
Want to buy my car instead?
lumpy
Adelaide, SA
Re: IJZ MKII Conversion Wed, 08 September 2004 08:39 Go to previous messageGo to next message
Are you seriously thinking about selling it Danish? After all that time and effort?
Re: IJZ MKII Conversion Wed, 08 September 2004 10:11 Go to previous messageGo to next message
I'm getting too old for turning steering wheels; that's a young man's game. Bring on the power assistance I say. Razz
Re: IJZ MKII Conversion Wed, 08 September 2004 10:24 Go to previous messageGo to next message
dave - that was my line and you know it!
Re: IJZ MKII Conversion Wed, 08 September 2004 10:31 Go to previous messageGo to next message
That's right - everyone know's it's Witzl with the gheyness and the aids.
BlackSupra
Re: IJZ MKII Conversion Wed, 08 September 2004 11:22 Go to previous messageGo to next message
Norbie wrote on Wed, 08 September 2004 20:31
correct.
V8_MA61
Re: IJZ MKII Conversion Wed, 08 September 2004 11:24 Go to previous messageGo to next message
backpeddler wrote on Mon, 10 November 2003 18:36
Thanks guys
Smile
im doing the r154 install right now, so pm me for more info exactly what to do and what you need. Ive also got pics of a dummy assembly showing the problem area.
Re: IJZ MKII Conversion Wed, 08 September 2004 12:33 Go to previous messageGo to next message
He asked that question last year... I don't think he'd be looking for an answer any more. Rolling Eyes
Danish
Re: IJZ MKII Conversion Wed, 08 September 2004 19:59 Go to previous messageGo to next message
Yeah Lumpy, I've reached my breaking point as of the other night.
I'm sick of getting screwed around my tuners and workshops and the amount of money it has taken and then the amount of money it has taken to redo a lot of things.
This car has a sad history which has eaten away at me for a long time. It's really unfortunate as it is 99% complete. Only the tuning remains, again, for the 6th time or so.
I just want to get rid of it before it costs me another 10k. I'd settle for something stock.
7M-Brisbane
Re: IJZ MKII Conversion Wed, 08 September 2004 20:47 Go to previous messageGo to next message
Trade for this? It's stock Very Happy
http://www.turbosupras.com/~lmdwyer/RT104/New Corona Damage.jpg
lumpy
Adelaide, SA
Re: IJZ MKII Conversion Wed, 08 September 2004 23:53 Go to previous messageGo to next message
Jeez mate don't sell it just because you can't get a decent tuner. PM or email with the workshops you've tried etc. There are some good and cheap people in Adel, but they're hard to find.
I know how you feel being sick of it all - but it's so close now, don't let some bad experiences with dickheads grind you down.
Re: IJZ MKII Conversion Thu, 09 September 2004 00:37 Go to previous messageGo to next message
Danish wrote on Thu, 09 September 2004 03:59
Hehehe, I know EXACTLY how you feel.
I had my conversion just sitting there collecting dust for 4 months because the tuner was retarded.
So in the end I said fuck it, and bought a Microtech, wired it up, and I've had 4 weeks of running rich as fuck fun!
Its finally gonna get some tuning on saturday, but I can still drive it none-the-less
Thruan
mackay
Re: IJZ MKII Conversion Tue, 28 September 2004 01:31 Go to previous messageGo to next message
hey Norbie what sort of power gains did you get with the 6M engine? how much did it all cost and how much work was needed???
Re: IJZ MKII Conversion Tue, 28 September 2004 02:36 Go to previous message
Damn, that's going back a while! From memory the engine cost me $900 and I was out of pocket almost $2k by the time it was on the road. This was in 1999 though so those figures aren't really relevant any more. Not much work is needed, it's mostly wiring and dramas with the dizzy, but that's only in you're using the 5M-E ECU. If you have a 5M-GE/6M-GE ECU to go with your engine it will be a lot easier.
Power gains were pretty major; the 6M-GE has at least 30-40hp more than the 5M-E, and it makes a huge difference. With a manual transmission it makes the car a lot of fun!
Previous Topic:Steering box reconditioning (TA22)
Next Topic:1G-GZE Diagnostic Port
Current Time: Fri Oct 16 14:47:55 UTC 2026
Total time taken to generate the page: 0.052333116531372 seconds
